86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine, Exhaust, Transmission
Old 05-30-2019, 11:12 AM   #29
RayRay88
Drives: 2017 86 860 Special Edition
Originally Posted by Westen86 View Post
I pictured tuning like moving a tent post under a tent. If you moved the peak, the immediate area around it would tapper off each end. But I guess thats a camshaft thing? But from what I hear, tuning is about pushing each peg as far up as possible without the peg getting pushed out. And the total engine determines the length of each peg.
Then Im looking for 150ftlbs from 3-5000rpm on 93. Kinda like this. And Im pretty sure thats all down to which header I put on.
Moving the powerband around like that is usually through a culmination of parts. Some of the main ones being; Intake manifold runner length, camshaft profiles, header design and then finally a tune to maximize it all.
Most 4-2-1 headers will give you a relatively flat torque curve on these cars, but don't kid yourself into thinking you can get modern turbo cars like max torque off throttle or V8/Large displacement levels of grunt.
I also highly recommend you throw the JDL 4-2-1 EL header on your list.
http://www.ft86club.com/forums/showp...&postcount=169
RayRay88 is offline   Reply With Quote
Old 05-30-2019, 11:31 AM   #30
Westen86
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
The ones Im leaning toward are the FT86 Catless, and the Ace CS400. Mainly because I dont want full boxer or full Honda noise from the exhaust. My first choice a long time ago was the HKS, until I heard it. But if something like the OFH2 or JDL uel gives me better results, I can go full Subaru.
WTB: Everything Velox/Verus
Westen86 is offline   Reply With Quote
Old 05-30-2019, 11:33 AM   #31
RayRay88
The JDL 4-2-1 is an EQUAL LENGTH header. It will not give you the boxer rumble.
The Following User Says Thank You to RayRay88 For This Useful Post:
CSG Mike (05-30-2019)
Old 05-30-2019, 01:47 PM   #32
Westen86
Westen86's Avatar
I just saw that in an older Ace 350 thread. It looks like the power is good, but doesnt come with an OP. It also matches the price of an Ace CS400 at $1400.
Old 05-30-2019, 02:31 PM   #33
RayRay88
The header just came out sometime Q4 last year. Older posts may be referencing the 4-1 not the new 4-2-1.
It's $1350 with ceramic coating. $1200 without.
$1200+200 for an overpipe =1400 about the same as a CS400.
I really don't care if you're set on a CS400 and don't care to compare the JDL but, for reference when other people come looking for answers, at least be factual and compare apples to apples.
Old 05-30-2019, 03:19 PM   #34
Westen86
Westen86's Avatar
Then I see stuff like this...
And it makes me want to buy a used Tomei and OP for $5-600 and deal with the rumble.
https://www.ft86club.com/forums/showthread.php?t=130575
Old 05-30-2019, 03:22 PM   #35
Lantanafrs2
Drives: 2013 frs red
Good idea imo. Otherwise you can debate this for infinity
Lantanafrs2 is online now   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
reeves (05-31-2019)
Old 05-30-2019, 04:16 PM   #36
Originally Posted by tomm.brz View Post
how are dynos in USA always put crazy values
when we in italy almost every dyno put around 133whp bone stock with 100Ron and you are lucky to get 160 whp with a catless EL header with 100Ron ecutek tuned
The % delta is what truly matters. Absolute readings should always be taken with a grain of salt.
This is why having a baseline is so important. Without a baseline, you can't get the % delta, and then, it literally becomes just a number.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
J1Avs (05-30-2019), Lantanafrs2 (05-30-2019), nikitopo (05-31-2019), why? (05-31-2019)
Old 05-31-2019, 10:18 AM   #37
bfrank1972
Drives: 2013 FR-S Argento
FYI there's a post on FB about a potential PTuning header group buy for just a smidge over 1K if anybody is thinking about that header.
IMHO if you want to stay NA and you want 'torque', I think it's a better buy to get a cheap used 'quality' header from the board here (i.e. P&L, JDL, that pops up), custom tune it, and use the rest for a FD swap. You could probably do all of that for the cost of one ACE header.
bfrank1972 is offline   Reply With Quote
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
J1Avs (05-31-2019), NoHaveMSG (05-31-2019)
Old 05-31-2019, 10:25 AM   #38
Westen86
Westen86's Avatar
This one?? Still a dip. Its a 200whp EL header.
https://www.ft86club.com/forums/show....php?p=1888721
Old 05-31-2019, 10:41 AM   #39
bfrank1972
Yup that's the one, it's one of the better headers out there. Just raising awareness as I saw it pop up.
Old 05-31-2019, 11:39 AM   #40
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Fking this.
Trueweltall is offline   Reply With Quote
Old 05-31-2019, 05:09 PM   #41
Lantanafrs2
Tomei for sale in classifieds. 400 bucks. I would start with those.
Westen86 (05-31-2019)
catless, dyno, header, torque, tuning
Search this Thread:
Advanced Search
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
