Old 08-24-2019, 01:13 PM   #155
vijay.dy06
Drives: Red BRZ
Originally Posted by spitsnaugle View Post
Got AC installed. It worked until I floored it and it threw the belt.
I'll detail the wiring to make it work later. Basically take the blue/orange stripe relay wire from fuse box, run it to AC trigger on GM ecu. Done.
Where did you get this weld on 90* fitting?
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 08-26-2019, 03:09 PM   #156
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Ludlow Automotive and Speed Shop in north Dayton did all of the lines, fittings and refrigerant for me. Was very reasonable at about $300 for everything.
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
all4spl (08-26-2019)
Old 08-26-2019, 04:16 PM   #157
all4spl
Wow sounds like a great deal! I'll need to find something local soon hopefully.
all4spl is offline   Reply With Quote
Old 09-06-2019, 11:10 PM   #158
spitsnaugle
Leaving for LS fest in a few hours.
Installed new Drive Shaft Shop 800HP axles and a new rear diffuser with the girlfriend:
Feeling like a lucky guy to find a girl into racing. She races a Miata that I shared with her last week while my LS2-FRS was broke last week.
GrabTheWheel (09-07-2019)
Old 09-09-2019, 12:35 AM   #159
Razorlor
Drives: 2017 BRZ Limited, Perf Package
Talked to you at LSFest, amazing car, can't wait to build mine!
Razorlor is offline   Reply With Quote
Old 09-24-2019, 06:30 PM   #160
spitsnaugle
Nice Meeting you there, the car got a TON of interest there. Wish I would have been able to get out and do some more racing, but after wearing the hoosiers down to the cords I called it quits.
Took 2nd on the road course in my class, and apparently won best engineered car, though I wasnt at the awards I had moved over to the carshow/manufacturers midway.
Couple of things I found on while the road course for the first time with the car:
  1. Tire wear wasnt even, I didnt really notice this in autocross.
  2. Tires are now shot
  3. Definitely gets fuel starvation at 1/2 tank in left corners.
  4. Winmax w4 pads were reasonably strong and didnt fade much (though I wasnt being super aggressive), but were extremely loud. It was commented on by spectators of how loud my car was.
  5. My fresh paint job did not enjoy getting beat by flying rubber.
Fixes:
  1. Going more aggressive with camber to 3.5*
  2. Hoosiers 245/40 front 275/35 rear now in garage
  3. Verus Fuel Door is waiting to be installed now.
  4. CounterSpace Garage C2 front pads and Project Mu Club Racer rear pads to be installed this weekend
  5. Ordered XPEL ULTIMATE PLUS paint protection film for bumper and lower quarters.
GrabTheWheel (09-25-2019)
Old 09-24-2019, 06:53 PM   #161
Razorlor
Couple of things I found on while the road course for the first time with the car:[LIST=1]
[*]Winmax w4 pads were reasonably strong and didnt fade much (though I wasnt being super aggressive), but were extremely loud. It was commented on by spectators of how loud my car was.
Can confirm, sounded like a school bus stopping.
Old 10-01-2019, 04:43 PM   #162
spitsnaugle
Got a Verus front splitter installed.
BRZ headlights installed.
Found a rather major issue though:
I think the rear output bushing on my trans is going. Anyone else ever hear this?
This sound only starts at 50+mph, stops at 30mph.
Clutch in/out no difference.
Gears vs Neutral make no difference.
Can be instigated and stopped by mild thrashing.
Sound location seems to be directly under the shifter.
Old 10-07-2019, 11:36 AM   #163
spitsnaugle
Installed VERUS fuel door flap to help left hand turn fuel starvation.
This is my first step short of dropping in a Radium basket/ surge tank.
Removed my TRD duckbill and installed a Varis Arising Hyper Narrow adjustable GT wing:
Irace86.2.0 (06-19-2020)
Old 10-17-2019, 02:33 PM   #164
spitsnaugle
Had a little tick after the last autocross. Turned into a knock on the road the next day, I pampered the car home and cracked open the oil filter to find a gold glitter bomb. Dropped the engine out in 4 hours. Split the trans and tore it down to the longblock to find the rods ate crank.
Full rebuild started. Rushing it to try to make it out to the last two events.
replaced almost anything oil touched:
Engine being washed and honed all around.
Heads being washed and reassembled.
k1 forged 3.622 crank (stock stroke)
wiseco 4.005 flat top pistons
callies compstar rods
LS7 Lifters
Melling 10295 oil pump.
ImprovedBaffle
Accusump
while I'm at it:
monster LT1-S clutch
new slave cylinder and remote bleed
new sikky short throw shifter
trans rebuild
If I had the time I'd do a mile 3.90 stroke, but that'd puts the turn around time to months. aiming to be rolling again by November 1st.
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
BigTuna (10-17-2019), Leonardo (10-17-2019)
Old 10-17-2019, 04:13 PM   #165
Merc
Drives: Subaru brz 2013 LS1 swap
Condolences my friend, may she rise from shrapnel and carnage like a phoenix even stronger.
Sent from my SM-N960U using Tapatalk
Merc is offline   Reply With Quote
Old 10-27-2019, 12:16 AM   #166
spitsnaugle
I dont like to waste time:
and its back in, but I need to loosen the motor mounts and re-center the tail shaft.
The Following 3 Users Say Thank You to spitsnaugle For This Useful Post:
BigTuna (10-28-2019), Irace86.2.0 (06-19-2020), Zer0 (10-28-2019)
Old 11-07-2019, 10:46 AM   #167
spitsnaugle
Onward:
Next morning after getting the engine in- directly onto the dyno to ensure all is well. It pulled 350+hp several times, tuner thought we were missing spark in a clyinder, so looking at the engine with an IR camera we saw one cylinder's exhaust was cold, wiggled the spark plug boot on a better and pulled 440hp and 426lbs torque. Nearing the limit of the injectors now. The stock fuel pump is actually keeping up, only dropping pressure from 60 to 45-50 at WOT.
Swapped oil filters after the dyno, drove it on the street two days to get some minor break-in... and hit the last autocross of the year. Constantly had a crowd around the car. I let a half dozen fellow drivers behind the wheel, everyone struggled with the clutch in the grid lanes, but once they were on course it everybody loved it.
This weekend its booked for a photoshoot for APEX wheels, then its probably going into hibernation while I do some minor upgrades for next year.
Old 11-07-2019, 03:03 PM   #168
vijay.dy06
Drives: Red BRZ
Nice, what size tires are you running?
cx racing, ls swap, ls2, pure automotive
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP ILLSMOQ Engine Swaps 172 11-24-2022 07:01 PM
LS2 swap by KAB Customs with Pure Automotive Motec Sportsguy83 Engine Swaps 254 10-17-2018 12:45 PM
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
