86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Old 09-21-2019, 08:59 PM   #1
mcnvgget
mcnvgget's Avatar
Drives: 2018 Toyota 86
control arms
so i just installed rear lower control arms and took the car out for a test drive and now my right axle is ticking like crazy, any information on why this happened? my car is lowered but i thought they were supposed to take stress off the axles and they were fine right before installing the control arms :/
mcnvgget is offline   Reply With Quote
Old 09-21-2019, 10:04 PM   #2
strat61caster
Thread Killer
strat61caster's Avatar
Drives: '13 FRS
What kind of control arm? Billet aluminum or stamped steel? Factory swaybar end links or aftermarket? Is the ticking sound like the tire/axle rotating or due to the suspension articulating?
Recheck torques on everything regardless.
ineedyourdiddly
Old 09-21-2019, 10:08 PM   #3
mcnvgget
mcnvgget's Avatar
steel control arms, factory everything else, when i press the gas no sound and ride is quiet but when i hit bumps and dips it ticks and crackles, and when i turn to the left and all the weight transfers to the right itís loud ticking during the duration of the turn, my left axle is fine no noises or anything just the right one
The Following User Says Thank You to mcnvgget For This Useful Post:
strat61caster (09-22-2019)
Old 09-22-2019, 03:28 AM   #4
strat61caster
Thread Killer
Drives: '13 FRS
Hard to tell on my end, check torques before replacing the axle imho, noise with lateral weight transfer sounds like suspension based, not drivetrain. Failing axle should be noticable in a straight line, might be wheel bearing though that would be very odd on such a new car.
ineedyourdiddly
SPC control arms and toe arms, whiteline camber bolts Tacticalpanda Brakes, Suspension, Chassis 1 03-08-2019 11:20 PM
wanted: rear control arms, toe arms & trailing arms Turbo Canada Classifieds 0 08-14-2018 12:18 AM
Need to buy: stock rear lower control arms/toe arms and intake elbow CoolHandMoss Want-To-Buy Requests 6 07-12-2018 08:44 AM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
