Tracking / Autocross / HPDE / Drifting What these cars were built for! |
04-11-2013, 12:14 PM | #15 | |
Or, something is wrong with the cooling system. For example, my S2000 started to overheat when it started warming up last year. The cause was the AC condenser in front of it was SO banged up that all the direct airflow coming in through the bumper opening was blocked. ALL of it. I was effectively only using the top half of the radiator, and wasn't overheating during the winter due to cooler ambient temps. Swapping in a fresh condenser solved the problem. I don't believe the stock FR-S/BRZ has a cooling issue as far as the coolant goes, but I would keep an eye on the oil temps. We ran around 80 laps in 100F+ weather at ACS last year at 86Fest, which is something like 96% WOT time without having any overheating issues. I'd say around 30 of them were back to back when we were giving vendors and attendees rides. |
04-11-2013, 12:14 PM | #16 | |
Drives: White FRS, 2011 Cayman, 1986 944
04-11-2013, 01:01 PM | #17 |
Guys as an FYI this is not a pot stirring thread, I am not saying the car is over heating or has a cooling problem. I am trying to establish, whether or not the stock radiator needs to be changed when adding oil cooler and inter cooler.
This car also have seriously buttoned up under hood area, seals on front and back of hood and skid plate allow for virtually nowhere for heat to dissipate. As of right now, my limited testing is showing higher temps stock, so this concerns me obviously. Sounds like you guys so far have mixed opinion, so please double check and post back if you can run logs.
04-11-2013, 01:04 PM | #18 | |
Drives: '13 BRZ / '11 Outback / '06 Tundra
04-11-2013, 01:08 PM | #19 | ||||
04-11-2013, 01:14 PM | #20 |
Drives: Raven Black
OP: have you considered using Engine Ice or Water Wetter? both are known to lower engine temps
04-11-2013, 02:21 PM | #21 | |
Engine Ice I will look at.
04-11-2013, 04:46 PM | #22 | |
Drives: Perrin/VORTECH Supercharger TestBRZ
I am sure FI cars spend less time WOT in the corners, I just happen to get thru the straights and the time between corners has decreased |
04-11-2013, 04:46 PM | #23 | ||
Drives: 2013 Black FR-S
04-11-2013, 04:52 PM | #24 | |
Search the FBM thread about radiators. Watch the VPMC video too. |
The Following User Says Thank You to sw20kosh For This Useful Post: | orthojoe (04-11-2013) |
04-11-2013, 05:07 PM | #25 | |
WOT time in corners depends on setup... I'm sure FI cars are running more tire |
04-11-2013, 05:39 PM | #26 |
Wasn't trying to be. Sorry I misunderstood your original post. I was trying to clarify what you were saying. My point was that an upgraded radiator has not been found necessary if you track the car. Forced induction changes the game, though and I agree with you
2013 Subaru BRZ
04-12-2013, 12:54 PM | #27 |
Going to do the Koyo Rad setup and separate oil cooler. Don't want to constantly be data logging and looking at gauges.
I will post back results when I have the video finished.
04-12-2013, 01:31 PM | #28 | |
Drives: N/A
Similar Threads | ||||
HKS Oil Cooler Kit - Keep those oil temps down. - Photos | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 23 | 08-10-2015 03:08 PM |
Muffler delete pipe = extreme temps at tailpipe?? | twincamRob | Engine, Exhaust, Transmission | 39 | 07-02-2013 08:12 PM |
summer or all-season tires? freezing temps? | rainmonkey | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 04-07-2013 01:11 PM |
Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
ECU pulls timing at high oil temps? | brillo | Engine, Exhaust, Transmission | 24 | 03-31-2013 09:10 PM |
