Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-07-2017, 08:05 PM | #57 | |
The Stig's German cousin
Source: I thoroughly dyno'd their shocks... |
The Following User Says Thank You to renfield90 For This Useful Post: | Racecomp Engineering (03-08-2017) |
03-08-2017, 11:23 AM | #58 | |
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CatDaddysBBQ (03-08-2017) |
03-08-2017, 12:43 PM | #59 |
Drives: '13 FR-S
Thanks Andrew. Always best to hear from the source.
My situation is that I want to lower the car as little as possible. It's my 17k mile a year DD that I do 7-10 autoX a year with maybe one HPDE on top of that. So while I want increased handling, it's got to be streetable in Chicagoland 4 seasons. I can handle stiffer ride as long as it's not crazy (owned a 2.25" dropped VW a while back and don't want to go there again). But ideally 1/2"-.8" drop is the desired outcome. I have (not mounted due to winter) a sticky set of 235mm tires that I anticipate will cause the OEM suspension to be overwhelmed when autoXing and HPDE as well. The OEM setup has been fine up to now (ran 215mm Pilot Super Sports so far, but making a big jump this season). I plan to wait until a first autoX (in about a month) to see what I think the car "needs", before I just drop money to buy tons of stuff. My thoughts are: If it's not TOO bad in terms of hitting bumpstops, etc but I want a bit less body roll, either RCE yellows on OEM shocks (and eventually upgrade those with Koni or B6) or Just buying Koni/B6 with either RCE yellow or tarmacs if the OEM is a bit worse than the first scenario. I've dumped enough cash on the car this winter that I don't necessarily have the 1000-1200 to toss at it right now unless it REALLY needs both, which is why i've had to ignore my friend's recommendations of RCE t2's, lol. We'll see I guess. One last question - let's say I went with yellows first, and then upgraded to b6 or konis... How much would I be "missing" with those shocks and yellows vs tarmacs? I can always sell the yellows and get both, but just curious how much there is between the two... |
03-25-2017, 08:13 AM | #60 | |
Drives: Toyota 86
I'm doing DD mainly and auto-x or track occasionally with Tarmac springs and Koni yellow since 2014. At the first time I've also experienced uncomfortable moments by lowered height. So I've ordered Subtle solutions spacers to reduce lowering. I've used 1/4" front and 3/8" rear and quite happy with them. |
The Following User Says Thank You to makinen For This Useful Post: | CatDaddysBBQ (03-25-2017) |
Similar Threads | ||||
Racecomp Engineering Yellow lowering springs install special! | Racecomp Engineering | Mid-Atlantic | 12 | 12-17-2015 01:34 PM |
BRZ lowered on RaceComp Engineering springs! | OrbitalEllipses | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 03-19-2014 06:26 PM |
Racecomp Tarmac II Clubsport coilover | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 11-16-2013 11:02 PM |
Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 07-28-2013 12:22 AM |
Racecomp Engineering | industrial | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 05-02-2013 04:17 PM |
