Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-27-2017, 10:33 AM | #491 |
Drives: 2016 FR-S
I've had mine on for about a month and change now. I enjoy the ride. I am 1.5 inch lower all around and have the dampeners set at 4 clicks from the stiffest. I think the ride can be even stiffer, 4 clicks is still a bit soft. I think that 6 clicks is about where the stock suspension felt. Our roads in south Florida are very nice, not concerned with pot holes. I did however manage to scrape my UL turbo manifold several times already, it hands about an inch an a half below the belly pan. So far I am satisfied with these coilovers, no noises or creaks. Next test is autocross, hopefully mid October.
The Following User Says Thank You to 86Craze For This Useful Post: | brybot (09-24-2018) |
09-28-2017, 09:35 AM | #492 | |
Drives: 2013 DGM BRZ, 2016 FiST
One last question: it was impossible for me to grab the spring and twist to lower it. I had to grab the threads with my hand and do it from under the spring. Preload was nice and snug. It was like something up top wasn’t letting it spin. Once again, I had no issues with the front or the Feal coils I had on my WRX. Thoughts? Thinking about it now, this probably jacked up my preload. Been busy but I’ll see if I can mess with the preload tonight. Last edited by fl4t ftw; 09-28-2017 at 10:57 AM. |
09-28-2017, 12:24 PM | #493 | |
Wheels for Brains
If you're worried about preload, take a pair of calipers and measure the distance from the top of the cylinder to the bottom of the spring lock. The factory reference dimensions should be available in the manual. |
09-29-2017, 07:29 AM | #494 |
Tein Flex Z opinion
Updating for anyone needing this information: lowering the rear preload will allow you to drop the rear just to the point where the tires basically sit flush in the fender (I have 255/35/18’s), maybe a tiny bit of tuck. I’m happy with my results and this is the perfect height IMO.
Sorry the pics kinda suck. |
10-04-2017, 02:56 PM | #495 | |
Drives: SWP BRZ
i lowered default so i am wondering. no rubbing? |
10-04-2017, 02:58 PM | #496 |
Tein Flex Z opinion
I didn’t measure it, just kinda winged it. I’ll make final adjustments soon. I haven’t rubbed yet but I only drove it a couple miles and need an alignment. Ride quality is surprisingly really good at 4 clicks from hard... at least compared to my FiST lol.
10-04-2017, 03:31 PM | #497 |
Drives: SWP BRZ
i am on 3 clicks. when weather gets colder, it will squeak little
10-10-2017, 09:34 PM | #498 | |
Drives: SWP BRZ
i just found my driver side rear is rubbing at fender. only happens at dips on highway though i have -1.4 driver side and -1.5 at passenger and i dont see any rubbing at passenger side though. 0.06, 0.05 toes I probably need to have more negative camber like -1.7 ~ -2.0 to be safe. EDIT: I found Passenger side has light rubbing mark as well. i probably go with -2 on all around to be safe Last edited by zc06_kisstherain; 10-11-2017 at 04:38 PM. |
12-26-2017, 10:07 AM | #499 | |
I'm going the check the preload again when it gets warmer (no garage ATM) but I'm not happy about false advertising. Again, I'm nowhere near 3" lower in the rear. Also seeing many other random posts and threads pop up about this issue with the Flex Z. |
12-26-2017, 08:21 PM | #500 | |
Drives: SWP BRZ
didnt touch with -1.5 at rear. hope this helps |
Similar Threads | ||||
Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 03:44 PM |
Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 03:22 AM |
WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 03:12 PM |
25% Off Tein Street Flex's!!! | RallySport Direct | Brakes, Suspension, Chassis | 0 | 12-31-2014 04:52 PM |
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
