Old 12-09-2014, 10:52 AM   #729
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by icebär View Post
So what is your new Alignment setup now?
I'm getting my KW Clusport Coilovers with ST Suspension Sway bars on Wednesday and would like to know what you drive! ;-)
Atm,
Front: Whiteline camber bolts(adjusted to -1.2deg)
Rear: Hardrace LCA w/Sperical bearing (adjusted to -2.3deg)
Front/Rear sways are Hardrace, both on softest setting.
RS-R coilvers are the Moto Spec ones, lowered 25mm
Might used some 3rd party camber tops for the front as I want to get more negative camber on the front. Either that or get some MCA coilovers.
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
Old 12-09-2014, 11:37 AM   #730
wootwoot
Drives: FRS
Correct me if I am wrong, but doesn't the RSR coilover kit have a reverseable top hat you can set to 0 or -1.5 in the front? Given that, you should be able to get a lot more negative camber if you turn them 180.
The Following User Says Thank You to wootwoot For This Useful Post:
stevo_12v (12-10-2014)
Old 12-10-2014, 01:07 PM   #731
stevo_12v
stevo_12v's Avatar
Hmmm not too sure. I got these 2nd hand so i didn't really do much research into them. I'll have to check with Moto if that's the case.
[CENTER]
Build thread
Old 12-12-2014, 01:34 AM   #732
stevo_12v
stevo_12v's Avatar
New Years Resolution completed :D
Finally cracked the 60 second barrier at Barbagallo last night
On my street tyres(Michelin Pilot Sport 3, 235/45/17), full tank of gas(had to refill and re-inflate tyres to 38psi) and full interior.
[CENTER]
Build thread
Old 12-22-2014, 08:32 AM   #733
GT86_PRAGUE
Drives: GT86
Originally Posted by stevo_12v View Post
My latest acquisition...
These are replacement bolts that are required when installing the SPOON Sports rigid collar set. I believe they are the rear ones(need to double check with City Toyota)
Why are these bolts required?
Also, you did only rear and why?
What do you think about this mod after time?
Thanks.
GT86_PRAGUE is offline   Reply With Quote
Old 02-06-2015, 01:42 AM   #734
stevo_12v
stevo_12v's Avatar
Thanks.
They are 'one-use' bolts only. The bolts are 'stretched' when installed, and not usually meant to be uninstalled. They have a specific shear strength and its better to be on safe side and just to replace them.
Haven't installed them yet, been too lazy :/
[CENTER]
Build thread
The Following User Says Thank You to stevo_12v For This Useful Post:
GT86_PRAGUE (02-06-2015)
Old 02-06-2015, 01:51 AM   #735
stevo_12v
stevo_12v's Avatar
Re-tune from United P100 to Shell V-Power
Was up for a tune today, did this last night. I replaced the resonator box in the engine bay. I previously plugged up the hole with a rubber stopper, but further research showed that its more beneficial to retain the resonator box.
Put the last remaining bits of my DEI Reflect-A-Gold tape on the engine side of the box, and used electrical tape to seal the connection between the airbox and the resonator to make it air tight(stock has 2 rivets holding it in place).
Pic below.
Thought I'd give a shot to see if my old TRD intake would fit the current setup. It won't work if you have the Crawford power blocks and the TorqueSolutions TB spacer installed. It *just* clears the sandwich plate of the HKS oil cooler though.
Here's some pics of the dyno.
Initial dyno power run on the car as-is(untuned) running SHELL V-Power. 177.3hp
Last dyno plot when car was on P100. 179.6hp
Comparison overlay of current hp vs bone stock hp. 183.3hp vs 129-130hp
Looking to do some more weight reduction. I believe the car's 'track weight' is around 1140-1150kgs or so now.
[CENTER]
Build thread
Old 02-08-2015, 04:27 AM   #736
stevo_12v
stevo_12v's Avatar
DI Cover Removal
1.333kgs saved
Didn't require to disconnect/reconnect the fuel lines to remove this. Just had to unscrew the oil filter and loosen and gently jiggle the DI cover out. Helps if you remove the bracket that's screw down to the cover also.
[CENTER]
Build thread
Old 02-27-2015, 08:13 AM   #737
icebär
icebär's Avatar
Drives: Toyota GT86
Atm,
Why so much Camber at the rear's? I would like to have only -1,2 deg. instead of 2.0 on my car, and -2.0 in the front.
Maybe I should invest some € in these: http://www.ebay.co.uk/itm/EIBACH-TOY...-/330950032314 Look oem and work well, adjustment up to 2.0 deg.
What is the total weight of your car by now?
icebär is offline   Reply With Quote
Old 03-02-2015, 12:50 AM   #738
stevo_12v
stevo_12v's Avatar
Normal weight is around 1200kgs flat. When I track and remove some other stuff, about 1150-1160kgs.
Going to get some front camber adjustable top plates soon, then will have the whole setup re aligned. -2.7 on the fronts and -1.7 on the rears.
[CENTER]
Build thread
SkAsphalt (03-02-2015)
Old 03-10-2015, 03:37 AM   #739
BRZ888
BRZ888's Avatar
Drives: 2014 Toyota GT86
Woke up and was pleasantly surprised to see this waiting for me.
Its a 4.556:1 drive ratio. This is the OG Toyota version, which CUSCO just rebrands. Don't bother getting the CUSCO version as it's wholly a Toyota part.
A potential +3 car lengths increase
This will most probably be installed in 2 weeks time.
Planning on getting my wheels painted(hopefully before Thursday).
Receiving my V70A R-Comps by Friday, and getting them fitted that day too.
Also ordered some STi Group-N Engine Mount and STi Group-N Transmission Mounts yesterday. Since I'm going to get my complete exhaust wrapped in DEI Titanium heat wrap I thought I might as well change the engine mounts while I'm at it(I forgot to last time around). With any luck this will be done Tuesday next week, and finally get the close ratio installed next next Friday.
This are the STi Group-N transmission mount(TOP). Bottom is Stock mount.
I think part of the CUSCO transmission mount might be able to work with the STi mount too, might have a try.
may i know the toyota part number of the ring and pinion?
BRZ888 is offline   Reply With Quote
Old 03-11-2015, 11:27 AM   #740
stevo_12v
stevo_12v's Avatar
Same part as this other member from this post:
http://www.ft86club.com/forums/showthread.php?t=52316
Also purchased from North Shore Toyota.
[CENTER]
Build thread
Old 03-18-2015, 08:11 AM   #741
stevo_12v
stevo_12v's Avatar
Front Camber Tops, Spark Plug check
Getting new camber tops fitted for my RS*R coilovers as I need more negative camber up front. Only running -1.2 or -1.3 camber if I recall.
Car keeps throwing a P0351 CEL code whenever I'm on the main racing circuit. So it will run fine for the first series of laps, then will bring up the CEL code. I proceed to reset after the laps, but the car after reset runs like its been detuned.
Also waiting for a Type 3 diffuser to come out. RB faux diffuser acts like a parachute at speed.
New STD Camber tops for the RS*R
Okada Coilpack
Diffuser Needed
Spark Plug after 1 year plus frequent tracking
Also had a 1/4 mile run two weeks ago. 15.2 seconds lol
[CENTER]
Build thread
Old 03-18-2015, 11:55 AM   #742
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I love how the rear axle is listed twice. EIGHT SIX DUALLY
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
36yroldvirginscar, keyboardwarrior, trd
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) -- General Topics 85 06-22-2012 05:22 PM
After this last winter is RWD such a bad idea Nate219BRZ Great Lakes 3 03-14-2012 05:03 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 12:29 PM
I have a great idea! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 56 07-24-2011 11:14 AM
Marketing Idea for the FT-86 JDMluv Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2011 05:29 AM
