10-05-2015, 11:15 AM | #29 |
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
10-05-2015, 02:46 PM | #30 |
Drives: '13 BRZ
So, anyone have a solid answer on having the dealer match the odometer?
10-06-2015, 03:10 AM | #32 |
Ah. So that's what caused problems for some people - using used clusters in their cars. Thanks for the info!
10-06-2015, 04:01 AM | #33 |
Drives: FT86
08-08-2016, 02:54 PM | #34 | ||
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
NOTE: When you swap the faces the STI numbers/letters no longer show in white - the stock USDM cluster has red LEDs, so it eliminates the white. For me, this is perfect as I prefer a red display at night, rather than a white/red as the STI has. Quote:
Wrong. Do not spread incorrect information. You can swap to a used cluster without issue. |
08-08-2016, 04:06 PM | #35 | |
Drives: Brz WRB - Europe LHD
08-08-2016, 07:19 PM | #36 | |
Drives: FT86
dude you need to read the brz\86 repair\service manual arround page 4985, it got the proceedures for pairing in new dash clusters it requires techstream or subaru ssm tool, else car aint going to start. were talking about swaping the entire cluster assembly not just replacing face plate and guage needles :-) |
The Following User Says Thank You to steve99 For This Useful Post: | Trap63 (08-09-2016) |
08-09-2016, 01:22 PM | #37 | |
08-09-2016, 05:58 PM | #38 | |
Drives: FT86
Thats very strange, i know a couple of guys that got into trouble swaping dash clusters and they had to get dealers involved to get car going again. I wonder if the used jdm cluster you bought had been "unpaired" by the seller, new or unpaired clusters you can swap in without the dealer software tools. |
08-09-2016, 06:50 PM | #39 | |
Sometimes cars are ecu tuned with key code not enabled (no verification is made during start up).....therefore no need to pairing is. But before any operation, negative on battery is required to be unplugged. If you buy it in Japan without VIN No. they send you unpaired, but if anyone orders with a VIN No. the cluster might arrive settled with proper VIN car code, so troubles might occour..
The Following User Says Thank You to Trap63 For This Useful Post: | steve99 (08-10-2016) |
08-10-2016, 08:32 AM | #40 | |
But I didn't have ANY issue putting the used cluster in, or putting my USDM back in after I removed the JDM cluster. Hopefully these posts help someone clear things up... |
The Following User Says Thank You to axelthrasher For This Useful Post: | steve99 (08-10-2016) |
08-10-2016, 11:19 AM | #42 | |
Or you can look to buy a used one on Yahoo Japan Auctions or a Japan -> USA importer. |
Similar Threads | ||||
Gauge install, dash cluster light cable, Tach RPM cable help... | Sportsguy83 | Electronics | Audio | NAV | Infotainment | 99 | 08-07-2016 10:36 PM |
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood | JPM Coachworks | DIY (Do-It-Yourself) Guides | 109 | 05-01-2015 01:19 PM |
led cluster help | Grip Ronin | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-14-2014 12:29 PM |
BRZ cluster on FRS? | Shipwreck | Electronics | Audio | NAV | Infotainment | 6 | 03-07-2013 11:09 AM |
Scratches on my Cluster. | Superhatch | BRZ First-Gen (2012+) -- General Topics | 5 | 08-21-2012 07:50 AM |
