Old 04-13-2017, 06:02 PM   #15
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Sorry, somehow I didn't get this notification. I'll get going on that... when I got some time.
KR-S (04-14-2017)
Old 06-02-2017, 02:12 PM   #16
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
[ame="https://www.youtube.com/watch?v=lhXoe-p0Xtk"]IT RUNS! The V12 QUAD TURBO Toyota 86 is alive! - YouTube[/ame]
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 12-18-2018, 11:52 AM   #17
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Pretty sure list is still missing Ferrari V8 swap, GTR VR38 swap, and BMW S85 V10 swap,
Old 01-17-2019, 01:32 AM   #18
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
13brew. He used the stock transmission. Not sure if he ever finished it.
glorydays is offline   Reply With Quote
The Following User Says Thank You to glorydays For This Useful Post:
RuyGuy2 (04-19-2020)
Old 02-01-2019, 11:42 PM   #19
Sonic86
Sonic86's Avatar
Drives: 2017 Toyota 86 MT White Drift Spec
Are there any known Mitsubishi 4G63T engine swaps?
Sonic86 is offline   Reply With Quote
Old 11-13-2019, 01:40 AM   #20
HachirocksU
Drives: Friggin Really Sweet
Hello,
Do you know where I can find this build?
HachirocksU is offline   Reply With Quote
The Following User Says Thank You to HachirocksU For This Useful Post:
Old 04-14-2020, 01:19 PM   #21
RuyGuy2
Dysentery Enthusiast
RuyGuy2's Avatar
Drives: 2017 toyota 86
If you took the front Half of an RX8 AZ6 It looks like it would bolt right up to the AZ6 in the BRZ. (Input shaft might be different too?) I had an RX8 and remember reading about guys who took close ratio kits for FRS and BRZ and used them to fix the AZ6 that came in the RX8 which for the first gen RX8 cars was junk.
With the way the frame is railed in the chassis making mounts for a rotary would be incredibly simple.
So if you swapped transmission front sections and took a 13b rew bolted it up than just made front mounts which on the engine. Than throw the Haltech 150 In be a cool way to have a super light 350 HP.
The thing I think it really crazy is the rear end gear and gearing in the transmission is almost perfect for a rotary....
RuyGuy2 is offline   Reply With Quote
Old 04-14-2020, 05:04 PM   #22
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I think I would rather have a LS1/t56 than a turbo 13b (weight is comparable), but I bet a 13b would be a cheaper swap.
Old 04-18-2020, 06:32 PM   #23
RuyGuy2
RuyGuy2's Avatar
I don't know about cheaper.... Good Rotary Engine is going to cost you 3 to 5 thousand dollars. About the same as a LS. The engine Management for a Rotary is going to be a lot more expensive...
Total weight is not the only consideration. The 13b has an Extreme advantage in weight distribution and over all weight.
Old 04-18-2020, 09:43 PM   #24
Irace86.2.0
"Good rotary engine". Is that an oxymoron?
Really though. A used eBay ls1 is going to be more than a used Renesis motor. Plus, you will get more power from the LS1.
From the video, the LS1 would sit lower, but be taller and protrude a more, but it has more power/torque than the Renesis motor. I suppose an LS of equal power would be that much lighter, smaller, etc. negating as much difference, and if we added a turbo kit to the Renesis motor to match the LS's power (turbo, piping, front mount intercooler, BOV, wastegate, etc) then there is even less of a difference in total weight and weight distribution.
Kind of a cool weight comparison between a LS and Miata longblock. And here is a link discussing weight differences between the LS and 13B FD:
https://www.rx7club.com/v-8-powered-...-639302/page2/
Old 04-19-2020, 01:16 AM   #25
RuyGuy2
RuyGuy2's Avatar
False.
Who was talking about a renesis? You can by from mazda a brand new crate 13b Rew right now for less than $4k. Stock 13b handles 450 HP pretty easily.
Once again who's talking about a renesis? 13B REW is what came in an FD RX7. The factory Twin Turbos with manifold are a whopping 35 pounds. a simple external wastegate single turbo setup that can support 450 hp for an 13b REW weighs around 20 pounds. In the link you posted below the guys talk about the FD RX7's gaining around 200 to 400 pounds.
Taylor Ray does a great job of proving the factory miata motor is a heavy piece of junk. He doesn't Touch on the rotary, Rob Dahm's video explains the difference much better. The rx7 club guys talk about how the car is heavier and hard to make fast on a race track, kinda obvious.
Old 04-19-2020, 02:22 AM   #26
Irace86.2.0
False.
That was a joke, if it wasn't clear. Wankels are cool for being different. My brother and I almost got him into a FD back in 2003. I'm a fan of the car and engine, but they have a lot of pit falls and short comings too that knock them off of my desirable-to-own list.
Uhhh, you. That is what was in the RX8. See below:
I have heard Miata and RX7 guys and 86 owners all talk about the handling being fine or sometimes better with the LS. Weight might be better, but some find the weight distribution to be better. Like Rob Damn shows, the crank position is actually lower. I think the handling effects are negligible. See comments @8:45:
Old 06-07-2021, 12:17 PM   #27
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
Here is mine. Project finished, car is running. Mechanical part of the swap kit and dressup kit is a complete own development.
https://www.ft86club.com/forums/showthread.php?t=138458
TRS is offline   Reply With Quote
The Following 2 Users Say Thank You to TRS For This Useful Post:
BrahmaBull1990 (06-07-2021), Dzmitry (06-10-2021)
Old 02-19-2024, 12:37 PM   #28
Rex1585
Any chance you could add mine to the list?
https://r.tapatalk.com/shareLink/top...ink_source=app
Sent from my Pixel 7 Pro using Tapatalk
Rex1585 is offline   Reply With Quote
fr-s engine swap for less than $20k squizzbeat Engine Swaps 51 03-20-2015 04:19 PM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
Engine Swap hybrid35 Southern California 0 01-07-2013 01:04 PM
4-AGE engine swap on FR-S bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 31 12-16-2012 02:23 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
