Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-17-2020, 01:15 PM | #29 | |
That Guy
Drives: 2013 asphalt FRS MT
01-17-2020, 01:32 PM | #30 | |||
Drives: 2013 FRS
Yes, the sway bars are equivalent to something like 22/16 solid. Considering tires now and may do an alignment soon. Quote:
I finally decided to commit and learn something rather than asking "what if" The entire purpose of putting on these sway bars in specific, or modifying the car in general, is to learn more about vehicle dynamics. And now I know a lot more than I did before. Even knowing ok, this is gonna be different, I should be careful, I was still caught off guard because I had no firsthand experience. I just knew, factually, it will behave differently. Now I know what it feels like, and the connection between stiffer rear --> more likely to slide out is reinforced mentally. I can also make an informed decision if I want to stay with the Eibach bars, or maybe look for something between these and stock rather than guesstimating. Running back home with my tail between my legs (throwing stock parts back on) for the sake of "not upsetting the balance" probably won't do me any favors. Quote:
It may be more likely to have sharp oversteer, but if you can ride that narrow line where you're drawing the maximum handling benefits but right before the limit of losing traction, then it would be a positive. The issue is if taking the new limit of grip is better or worse than before. Sure, it's possible that even a novice driver on the stock parts, could take a turn better than an experienced driver on these sway bars, but I'm doubtful that's the case here. Think about an F1 car. Assuming I can even get it moving, just because I spin out doesn't mean the car is poorly set up. It's an extremely fine-tuned precision instrument. Suspension designed to perfection. Me spinning it out doesn't give me any right to say "obviously the rear sway bar is too big." Now that I've had a chance to drive the car in a variety of conditions, it's been interesting. I've still been cautious, but it hasn't swung out on me at all. I pushed it through a few highway exit ramps, and it easily stayed tight to the inside even already going faster than I expected. |
01-17-2020, 02:39 PM | #31 | |
My point was ignoring driver skill... too much roll stiffness for the rest of the setup (tires especially), especially from just sway bars, can end up with less mechanical grip even with the best driver behind the wheel.
The Following User Says Thank You to wparsons For This Useful Post: | RayRay88 (01-17-2020) |
01-17-2020, 02:58 PM | #32 | |
Drives: 2017 86 860 Special Edition
A good approach is, do not throw on a part unless you know what behaviour or problem you're trying to fix. If you know your issue/problem then work smart to understand what part is best suited to address said problem within the confines of your means (time, budget, etc.) It sounds like you knew a higher roll stiffness in the rear would induce oversteer and you just reinforced it by buying a stiffer bar. That is not something one would say was a good purchase. Also, just because Eibach makes stiffer bars, doesn't mean the car requires it. It's a bread and butter part for them and other aftermarket companies. Their product development usually goes something like this: New platform released>Take stock bar diameter and +1/2mm>Sell product. The simple fact is that you changed suspension parts while running on all season tires, this alone tells us you did not do adequate research prior to purchasing these parts. |
01-17-2020, 09:07 PM | #33 |
Drives: 2013 FRS
01-17-2020, 10:11 PM | #34 |
I am guilty as well of buying parts just to learn. The knowledge can be just as valuable as an increase in performance.
The Following User Says Thank You to norcalpb For This Useful Post: | Stomachbuzz (01-18-2020) |
Similar Threads | ||||
FS: Cusco Strut Bars and Power Braces, Hotchkis Sway bars | armyoffoo | Brakes, Suspension, Chassis | 10 | 08-08-2018 08:28 AM |
TRD anti-sway bars installed in my FR-S | babydriver | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 10-01-2016 08:58 PM |
FR-S stock sway bars compared to TRD bars | babydriver | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-01-2014 09:12 PM |
BRZ / F86 Sway bars | timlewis82 | Australia Classifieds | 3 | 02-02-2014 03:06 AM |
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 06:00 PM |
