BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
01-01-2014, 01:52 PM | #1 |
Drives: Suburu BRZ Limited, black
Electric power steering assist to remote control
I was thinking about how the power steering on the twins is servo-electric, and the thought came to me... You could probably wire that up to a remote control system. In addition, the throttle is drive by wire as well, so that could be setup to be computer controlled. Is the ABS system also accessible by software? In which case, you could, with a bit of wiring setup the entire car to run by remote. Of course this would be a bit more effective with an automatic... but it could be handy for a 6 speed if you left the car in first gear and then remotely controlled it into a parking spot. That is assuming you had some kind of visibility or safety so it didn't go crashing into things. That's all hypothetically speaking of course, but it'd be a neat trick to do on a car that's far less expensive than an E-Class.
The Following User Says Thank You to SeanBlader For This Useful Post: | M-17 (01-03-2014) |
01-01-2014, 02:12 PM | #2 |
Drives: waiting on a 2021...
I think the steering is electric assisted. I don't know if the motor is strong enough to turn the wheels by itself. What I wonder is if you could hack into someone's car through the Bluetooth OBD2 scan tool a lot of people leave plugged in their car when they have the Torque App?
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
The Following 2 Users Say Thank You to zooki For This Useful Post: | M-17 (01-03-2014), strat61caster (01-01-2014) |
01-01-2014, 02:48 PM | #3 |
Drives: '13 FRS - STX
I think Zooki is right, this car still requires mechanical input to steer, you cannot control the steering based solely on electronics.
This is what you're thinking of: http://www.caranddriver.com/features...emains-feature But yes it seems sound that you could hack the drive by wire and eventually the steer by wire systems to mimic a driver input with code and subsequently a remote control. |
The Following User Says Thank You to strat61caster For This Useful Post: | M-17 (01-03-2014) |
01-03-2014, 02:40 PM | #4 |
Drives: Altima
Looks like it's been done on an S2000:
[ame="http://www.youtube.com/watch?v=cXuaswqvdxU"]EPS-1.mp4 - YouTube[/ame] |
The Following 3 Users Say Thank You to tnE30fan For This Useful Post: |
01-03-2014, 02:55 PM | #5 | |
Ninja Cat Mod
Education is Important, but Race Cars are more Importanter |
01-03-2014, 03:18 PM | #6 |
Here's the technical info on that S2000, I'll admit I didn't look it over too closely. The system in the Toyobaru is fundamentally the same as what's on the S2000, the details will change but the same result should be obtainable (maybe not reasonably so).
http://modifry.com/freebies/eps.htm I honestly didn't think that was possible, very cool hack. In order to turn into something other than a party trick there would have to be a significant amount of control systems worked out, basically you'd have to build a front end over what he's done in order to get controllable repeatable results out of the system, some heavy caster may help as well allowing the front end to track back to straight more aggressively (tires out humans but not circuits). And of course you risk overworking the system and causing a premature failure of the control unit or motors providing the assistance. |
01-07-2014, 10:16 AM | #7 |
Drives: Altima
Just to add, Modifry has a great reputation in the S2000 community as being responsive and helpful. He's obviously very smart as well, as evidenced by the products he's come out with for the S2000.
Anyway, all that to say that if someone wants to explore this concept further, they can always send him an email. |
Similar Threads | ||||
Scion FR-S RGB MULTICOLOR DRL Bulbs: Plug & Play! Control W/Smartphone App | Diode Dynamics | Exterior Parts - Lighting | 84 | 09-10-2021 10:25 AM |
Remote control FRS | draggin_az | Off-Topic Lounge [WARNING: NO POLITICS] | 50 | 12-24-2013 02:18 PM |
Electric Power Steering control module? | slicktop | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-21-2013 08:38 PM |
Toning down the electric steering pump possible? | kertong | BRZ First-Gen (2012+) -- General Topics | 18 | 03-03-2013 12:51 PM |
Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
