01-01-2017, 03:51 PM | #701 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
So I'm working on installing the OEM Oil cooler, and after removing the skid plate, I notice this!
I take it, it's a head gasket leak? This wasn't hear last time I went under the engine... which was when I installed the Nameless headers about a year ago.
01-01-2017, 04:09 PM | #702 |
Drives: frs
Try an engine compression
01-01-2017, 06:17 PM | #703 |
01-01-2017, 08:43 PM | #705 | |
Drives: 2016 Cosworth 2.2 BRZ
If it's a head gasket leak, you'll know it. Like said, you may have low compression or antifreeze in the oil which will make it milky. You may even smell antifreeze in the exhaust. If your oil looks fine, then I would clean the engine off and put some UV dye in it. You can get it from Advance, Autozone, Walmart, etc... Clean everything off at the car wash and then put in a small bottle of dye. Drive it for a few days and then check with a UV light. Most mechanics can do this. They can pinpoint exactly where the leak is and tell you what you need to fix it. |
The Following User Says Thank You to sly For This Useful Post: | weederr33 (01-01-2017) |
01-01-2017, 08:56 PM | #706 | |
01-01-2017, 09:05 PM | #707 |
No idea. But it would be a lot cheaper to fix a valve cover leak than a head gasket. I'd start with the dye and go from there.
01-03-2017, 10:39 PM | #708 |
Drives: 2013 Scion FR-S 10-Series
Can someone tell me the part # for a spare belt? I know I read it here somewhere but can't find it?
01-04-2017, 11:42 AM | #709 |
It's the Gates 6PK2315
The Following User Says Thank You to weederr33 For This Useful Post: | Insurme1 (01-08-2017) |
01-05-2017, 05:28 PM | #710 |
Drives: blue - Cosworth SC stage 3.0
If you've not been losing coolant its certainly an oil leak from either the rocker cover or the front cover
there's no actual gasket for either both are sealed with sealant |
The Following User Says Thank You to Matt@Cosworth For This Useful Post: | weederr33 (01-05-2017) |
01-20-2017, 05:15 PM | #711 |
OEM Oil Cooler, via the capped off throttle body pieces was installed today. Wasn't very hard. The only problem was trying to bleed the coolant since the supercharger throttle body is directly over the bleeder.... Otherwise, looks great with the Stage 2 kit!
01-30-2017, 10:46 PM | #712 |
Matt, was this pulley ever produced?
01-31-2017, 02:08 AM | #713 | |
Drives: GT86 Cosworth
I will be interested what you oil temp settles to on the highway. Do you have the low temp theromstat? |
01-31-2017, 10:17 AM | #714 | |
Since I don't really track my car, it should be OK for now.
Similar Threads | ||||
Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4306 | Yesterday 06:23 PM |
Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6004 | 03-19-2024 02:16 PM |
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
Phantom FTS Electric Supercharger Owners Thread | TM | Forced Induction | 1206 | 12-15-2019 02:33 PM |
Supercharger Kits! Vortech/Cosworth | RallySport Direct | Forced Induction | 61 | 06-29-2015 11:26 AM |
