12-13-2018, 10:11 AM | #29 |
Site Moderator
Drives: Stuff
It's really not that easy to bend a drive shaft.
However, I also have a little bit of a hard time believing a scammer will meet up with the person to do a trade in cash. I don't know why the OP didn't take the seller up on his offer of using the warranty (assuming that offer was really made). Not sure we will ever get to the bottom of what happened to the driveshaft.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
12-13-2018, 04:54 PM | #30 | ||
The Following User Says Thank You to Tcoat For This Useful Post: | arkanist (12-13-2018) |
12-13-2018, 05:10 PM | #31 |
Panda Trueno
Drives: No twin now.
12-13-2018, 05:41 PM | #32 |
Drives: GR Corolla
12-13-2018, 05:48 PM | #33 |
Drives: 2014 Subaru BRZ
Sir.....
The Following User Says Thank You to VIP BRZ For This Useful Post: | arkanist (12-13-2018) |
12-13-2018, 06:02 PM | #34 |
Drives: Not a BRZ
12-14-2018, 08:26 AM | #35 |
Disagree. It is all in getting a free range not a feed lot one. The free range is much better since they are not filled with hormones and waste products. Even the best feed lot ones are no good no matter how you prepare them.
The Following User Says Thank You to Tcoat For This Useful Post: | GalloVecchio (12-17-2018) |
12-14-2018, 06:28 PM | #36 |
Drives: Argento FR-S
Holy crap this got stupid . I bought it ONE MONTH prior to contacting him about the problem, not two. I didnt get a chance to install it for two weeks, but did roll it on a flat floor when I got home and it rolled flat. It stayed rolled in carpet under a shelf until I had a chance to install it. Amazingly, two weeks later it was unharmed by the jagged and abrasive burbur carpet I so haphazardly rolled it in. Install was easy, I know how to use a torque wrench and I've done this many times on many different cars, trucks and a van or two. When I did, it vibrated badly above 70 and lost power at all speeds. My 1st thought was I installed it incorrectly somehow. I took it off, checked to see if it still rolled flat (it did) and reinstalled it in a different position. Same thing in all 4 positions. I took it to a local shop where they told me it was out of balance and said some other shop could probably fix it. That's when I contacted the seller and got his reply. Since then for shits and giggles I installed it on a friends BRZ. Same shit, different car. I understand that I didn't install it right away and didn't contact him with my concerns until a month later. If someone contacted me a month after I sold them something saying it was broken, I'd be suspicious too. But nothing happened to it while I had it. I also have a hard time believing it was fine on his car and not two others. Unless something happened between the time he took it off and the time he sold it to me. Now I'm stuck with an out of balance driveshaft that's going to end up costing me more than a new one once I get it fixed.
Sent from my SM-G892A using Tapatalk |
12-15-2018, 03:01 AM | #37 | |
How much would it cost for a new driveshaft? If it's cost effective to have it balanced, I suggest you have it balanced and keep the receipt with a note from the shop, that it was in fact out of balance. Then send a copy of the receipt and the shop's statement to the seller and ask him to pay half of the cost to have had the driveshaft balanced. If the seller refuses, chalk that up to experience - about buying used stuff. humfrz |
12-15-2018, 11:52 AM | #38 | ||
Drives: 2015 FRS
The Following User Says Thank You to teetsdownlow For This Useful Post: | FRSBRZGT86FAN (12-15-2018) |
12-15-2018, 12:00 PM | #39 |
Drives: 2015 FRS
Check out driveshaft pro in SD and Oceanside driveline in Oceanside. Should help you get fixed up
The Following User Says Thank You to teetsdownlow For This Useful Post: | Hadalet (12-15-2018) |
12-15-2018, 03:02 PM | #40 |
I am kind of confused. Got the shaft, waited a while ,then put it on and vibrated. went to a shop and was told it was bent. Last post says he checked for straightness when he got it and was ok. Now says it is out of balance. What did the first shop check to find it bent after he said he check and it was strait? Usually the weights are mounted on the outside making floor checking impossible. Are there points indicating the weights have come off?
More questions than answers. |
The Following User Says Thank You to ls1ac For This Useful Post: | FRSBRZGT86FAN (12-15-2018) |
Similar Threads | ||||
So what do you do if you get scammed? | Webster10 | Scion FR-S / Toyota 86 GT86 General Forum | 136 | 12-10-2015 06:37 PM |
WARNING: Think I was scammed by Norcal86 | raven1231 | User/Vendor/Sponsor Reviews, Feedback, Comments | 69 | 10-28-2014 02:29 AM |
Scammed by frs owner | Prowl647 | BRZ First-Gen (2012+) -- General Topics | 4 | 08-20-2014 02:52 PM |
