Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
11-03-2012, 09:30 PM | #1 |
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Will an Alcon wrx kit bolt-on to BRZ/FR-S??
Hi guys I'm looking at purchasing a second hand Alcon mono4 street brake kit for my "twin". The kit was sold to suit a wrx 2002-2007 and the seller claims it is compatible with the brz/fr-s.
I know the STi Brembos bolt on so theroreticly all of the bracketry and rotors should be compatible with this kit. I am unsure about the brake lines though and also didn't realise that the wrx shared the same 5x100 stud pattern with the brz. Can anyone offer any insights? |
11-03-2012, 09:32 PM | #2 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
read up on Sri bremno threads front should work after swapping bleeders to the other side (unless the pistons are equal size then just flip the caliper). But I think the rears are lgt brakes, but I don't remember exactly.
The Following User Says Thank You to finch1750 For This Useful Post: | spiller (11-06-2012) |
11-04-2012, 05:08 AM | #3 |
So the bleeder needs to be at the top or the bottom?
11-04-2012, 05:14 AM | #4 |
That Guy
Drives: 2013 asphalt FRS MT
11-04-2012, 05:16 AM | #5 |
11-05-2012, 11:37 AM | #6 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The Impreza brake calipers are mounted on the rear side of the hub. So if you swap them to a BRZ then the bleeder valve will be on the bottom. If the bleeder valve is on the bottom you will not be able to bleed air out of the brake system, because air rises to the top.
11-05-2012, 12:57 PM | #7 | |
Site Moderator
Drives: Stuff
If the alcon stuff is differentially bored then you'd mount the left alcon WRX one on the right side of the BRZ, right WRX on left side of the BRZ and switch the transfer tubes from the top to the bottom and bleeders from the bottom to the top, basically similar to what you do with the STI calipers. This assumes the alcon's are external transfer tubes, if they are internal, and there's no ports on the other end for switching the bleeders, then you either run them with the differential bores backwards (not the end of the world, but I wouldn't do that) or get something designed for the car, or that can be made to work.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
The Following User Says Thank You to Dave-ROR For This Useful Post: | spiller (11-06-2012) |
11-06-2012, 03:43 AM | #8 |
Dave thanks for explaining, makes sense. What is the sinificance of the differential bores? Do they need to be in a particular order? I'm pretty sure these calipers have internal transfer tubes but the bleeders are reversible according to the seller.
11-06-2012, 04:16 AM | #9 |
Drives: Attitude
Uneven pad wear will occur if the bores are in the wrong order. STI Brembo calipers are differentially bored so the right and left side must be swapped to get the pistons in the right order on each side; following this the bleeders must be swapped from bottom of the caliper to top. Sounds like the same process on the Alcon units.
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | spiller (11-06-2012) |
11-06-2012, 04:57 AM | #10 |
So if the bracketry is to suit an impreza, technically it should match up to the brz if it is also swapped to the opposite side with its corresponding caliper?
11-06-2012, 05:46 AM | #11 |
Drives: Attitude
Knuckles are the same as the Impreza, or should be. Impreza bolt holes fit the Brembo calipers, with new bolts. Alcon calipers should bolt up on either side, the dynamics of the pistons and bleeders is what requires switching sides. That car had heavy front bias...not sure why you wouldn't want to just sell the Alcons and buy something meant for this car.
11-06-2012, 07:25 AM | #12 | |
11-06-2012, 06:46 PM | #14 |
Math has already been done for the STi front and rear kit you mean?
Similar Threads | ||||
Camber Bolt Help Please! | ft86Fan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 114 | 02-27-2019 11:13 AM |
FS: Wedssport TC105N 18x8.5 +43 & Alcon 4 piston Calipers | Gambit | Australia Classifieds | 26 | 05-11-2014 08:38 PM |
Bolt-ons + Tune Power? | industrial | Engine, Exhaust, Transmission | 54 | 09-05-2012 09:53 AM |
Crash bolt question | ayau | Tracking / Autocross / HPDE / Drifting | 8 | 08-17-2012 01:22 PM |
BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
