Old 04-05-2015, 12:43 PM   #15
Koa
Sweeper
Koa's Avatar
Originally Posted by Amir Ghadiri View Post
My FA was making 300whp before my rebuild and I never had any transmission problems. Although I have had synchro problems, even on stock power, I never had an actual failure. I wouldn't need to be making over 350whp on the LS. As far as modifying the transmissions, I would just need one bell housing made to fit and I could swap it out if I swap a transmission.
I'm not saying this is what I'm going to do, it's just an option. I really just want to see if anybody has already made a bell housing to mate the stock trans to an LS
It's anecdotal evidence you're trying to present man. Perhaps you didn't ever take it to the track; perhaps you've been very gentle on the rolls; perhaps you've never launched it; perhaps you're just lucky
Dip is trying to give you some evidence that he's witnessed and corroborates with others'... so bro. what are you really trying to do here- are you trying to gather information or are you trying to convince us that your idea is sound and you won't have to throw more money into your pipedream ls rig?
The Following User Says Thank You to Koa For This Useful Post:
Dipstik-sportech (04-05-2015)
Old 04-05-2015, 01:07 PM   #16
Amir Ghadiri
Amir Ghadiri's Avatar
Originally Posted by Dipstik-sportech View Post
Obviously it's not where it needs to be if youre doing an LS swap. The m85 diff is no stronger that stock, BTW you're welcome for finding out it fit. A clutch will still fail if you constantly clutch kick drift it. Just sell the stock trans. I'm unsure if you were actually serious or if this was a late April fools joke really.
Look guys, I get your point. The stock transmission is NOT the best (or even a viable) option for an LS swap (I never did say it was) - but please understand that the point of this thread was not to gauge opinions. My only question was if somebody has developed a method to mate the stock transmission to an LS series motor. If someone had already made a solution for this, I would have considered using it, but based on your responses it appears nobody has (or ever will).
You win, I'll find a T56 and break that instead
Amir Ghadiri is offline   Reply With Quote
The Following User Says Thank You to Amir Ghadiri For This Useful Post:
hmong337 (04-06-2015)
Old 04-05-2015, 01:16 PM   #17
Amir Ghadiri
Koa Dipstik-sportech Since you both seem to know a bit more about the swap than me anyways, perhaps you could shed some light on a different aspect of it?
I already all the mechanical parts of the build taken care of. Yes I will still need to find a T56, but that's not going to be a big deal.
I will be running a standalone engine management & fuel injection system on the motor. Getting the motor itself running properly and tuned will be NO problem.
My question is, do you know what I will need in order to make the rest of the factory electronics work well enough for me to be able to drive the car? Gauges and other amenities aren't a big deal, I just need to be able to start the car, drive it without traction control interfering, etc.
Any input you give would be appreciated here
Old 04-05-2015, 01:19 PM   #18
Koa
Sweeper
Koa's Avatar
https://www.google.com/webhp?sourcei...3aft86club.com
lots of discussion already on how to make the BCU and other systems, including Traction Control, to work with the car.
Old 04-05-2015, 01:21 PM   #19
Amir Ghadiri
Thank you very much
Koa (04-05-2015)
Old 04-05-2015, 02:06 PM   #20
Koa
Sweeper
Koa's Avatar
Thank you very much
good luck man it will be very fun if you get it going
Old 04-06-2015, 04:54 AM   #21
andrew5826
Seņor Member
andrew5826's Avatar
Drives: BRZ SWP
bro go out and buy a drift missle... poo40 sounds good
andrew5826 is offline   Reply With Quote
Old 04-06-2015, 12:35 PM   #22
Amir Ghadiri
lol you know me from the gpn days, I have to go overboard. I could build my vert but I need an excuse to fix the frs
Old 04-07-2015, 07:37 PM   #23
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
I know someone who may be interested in those stock transmissions
Darryljr11 is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 07:44 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 05:04 PM
