06-30-2017, 04:10 PM | #4047 | |
06-30-2017, 04:28 PM | #4048 | |
You won't need a pressure/temp gauge; the system is already proven. If you want one anyways, I would recommend using an OBD2 type device, or getting a P3 vent gauge for stealthyness. Should I have @CounterSpace Garage schedule you in for an install? CSG is only about 90 minutes away from Oxnard. |
The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (06-30-2017) |
06-30-2017, 04:58 PM | #4049 | |
pessimistic skeptic
06-30-2017, 09:01 PM | #4050 |
Drives: frs
I need these seal for my JR engine oil kit I bought from you. Do you have them?
06-30-2017, 09:33 PM | #4051 | |
Drives: 2017 86 Coupe
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter |
07-02-2017, 12:24 AM | #4052 |
poverty cause racecar
Drives: Subaru BRZ JRSC'd
I'm sure owners here are familiar with the fluttering sound the SC makes when off throttle at high rpm which sounds a lot like compressor surge. At my local tracks the car sits at this high rpm through long bends frequently and was wondering whether the long term reliability is compromised by the compressor surge, would switching to a proper blow off valve be a possible solution or should I just stick with what I have?
07-02-2017, 03:24 AM | #4053 | |
07-02-2017, 01:51 PM | #4054 |
It is, my mechanic even zip tied the vacuum lines just in case. There are three of us with the same kit in a group chat and they all sound the same so I'm assuming they all do it unless we got a bad batch of by pass valves. But below 6k rpm they make the whooshing air sound. Just at the high rpm does it make the compressor surge sound
07-02-2017, 03:55 PM | #4055 |
Drives: 2014 BRZ
Not familiar with this. Do you have a recording?
07-02-2017, 08:41 PM | #4056 | |
pessimistic skeptic
07-03-2017, 02:47 AM | #4057 | |
It should be a singlar "woosh". The way the kit is designed, compressor surge is virtually impossible. There's a reason why the bypass is directly after the supercharger. |
07-04-2017, 10:45 PM | #4058 |
Working on the video clip, it's a. It obscure with internal go pro mic so I'm trying to grab an external mic so you guys get a more accurate sound!
07-24-2017, 03:58 PM | #4059 |
Drives: Raven Black Scion FRS
anyone else getting weird thump sounds under abrupt throttle? Inlet tube seems to be compressing.
@thomsonsss
Black (Raven) D4S Scion FRS (Sold)|| Black (CBP) FK8 Civic Type R || Black (BSM) F80 M3 Comp (Sold) || Black (Jet) E46 M3 || Laguna Seca Blue (LSB) E46 M3 (Sold) || Alpine White (AW) E92 M3 || Carrara White 997 GT3RS Last edited by adjusts; 07-24-2017 at 10:07 PM. |
07-24-2017, 08:24 PM | #4060 |
Drives: '14 WRB BRZ | '17 CB STi
For those of you running a C38 with the high boost pulley on e85, can you comment on how it feels? I keep seeing comments on this forum and elsewhere that this kit is "underwhelming" in pull, but I find it hard to believe a 2800lb car with 370whp is underwhelming in feel or performance. I'm guessing most of those comments are directed towards a fairly stock car with 91 octane.
Can anyone here comment on overall feel at that boost and power level?
PR138
IG: @pr.138 2008 LBP Honda S2000 2013 UM Scion FR-S |
The Following User Says Thank You to PR138 For This Useful Post: | CSG Mike (07-24-2017) |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
