Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Software Tuning
Old 10-05-2019, 12:42 AM   #1
solidsnake11
Drives: brz
Why is midrange so flat after a new flash?
After flashing it takes my car around 2 days to get its midrange back? IAM is set to 1. Up to 4000 pulls good then its flat until around 6000rpm when full boost comes in. After 2 days it pulls great until full boost comes in at a lower 5500. Its around 3 lbs of boost at 4500, 12 lbs for full boost for now.
solidsnake11 is offline   Reply With Quote
Old 10-05-2019, 07:34 AM   #2
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Drives: 13 Firestorm Red FRS
Who is tuning it? Are you logging LTFT? Did they change anything with the tune?
Let me try to reword how I'm understanding this. You reflashed the car, it pulls good until 4k, when you have positive boost pressure. After 6k you have built up to 12 psi and the car pulls hard again.
2 days after this, the car pulls good UNTIL 6k and then it loses its power? This sounds like timing and fuel are being bamboozled up top. Check your LTFT and timing in areas where the car bogs in datalogs. Most importantly, let your tuner know.
Do you have and datalogs you can share with us?
Old 10-05-2019, 09:44 AM   #3
solidsnake11
Drives: brz
My engine is 10.5 to 1. gt4202r turbo and I am tuning using rom raider and mafscaling 2.51. Full boost always pulls hard just slower to get there after a flash. ltft is 0, revlimt is set at 8k
Old 10-05-2019, 11:07 AM   #4
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Please get a turbo blanket, you're defeating your intercooler but not protecting the piping going to your throttle body.
Anyway, without datalogs it's tough to pinpoint causation. I'm assuming that these runs are done WOT and with the car at the same temp? Have you tried reflashing the exact same map right after the car does a "good" pull to see if driving right after results in the issue you're describing?
I'm going to assume you're tuning it yourself if you're using Romraider. Can you datalog a good run, a bad run, and present them here?
Old 10-05-2019, 02:14 PM   #5
solidsnake11
Drives: brz
How much drop in IAT should I expect with a blanket?
Old 10-05-2019, 02:27 PM   #6
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Not sure, I just know that the goal is to keep the air as cold as possible. The slightly cheaper alternative would be to at least put some gold tape on it, but it looks tacky in my opinion. I'm getting a blanket for mine soon because it superheats everything in the area.
The one advantage you have are the badass track spec hood vents. It rains a lot here and my car gets driven every day so I just can't add vents . For a PTP blanket it's less than $200. I'd say it's worth it with your turbo being so big.
Old 10-05-2019, 04:43 PM   #7
solidsnake11
Drives: brz
Just wondering because IAT is at 91f at 12lbs of boost with ambient of 88f. You think I can get below ambient with a turbo blanket?
They do look good but I don't have any.
Old 10-05-2019, 05:21 PM   #8
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
I'm not sure why I thought you had them. Well if you're comfortable with the heatsoak when you're not flat out then it's fine
Old 10-07-2019, 09:31 PM   #9
solidsnake11
Drives: brz
Large turbines are less restrictive so they don't get as hot as smaller ones. Large compressors also don't stretch the air that is entering the turbo as much, which also keeps charge tempature down.
Old 10-08-2019, 03:33 PM   #10
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
When you say flash, are you e-tuning or dyno tuning? You really need to dyno tune it to get the most out of the setup. As far as it getting its midrange back after two days, I would datalog it after a flash, and then datalog after it gets the midrange back and compare the two side by side. It may be difficult but it can be done. This is really all the advice anyone can give without seeing the logs. Well.... this may be happening but I dont know. On some of these vehicles, the Exhaust cams don't like to swing for a while after flashing. We've experienced this a few times, but the problem is very pronounced. What you could do is just plug in and log VVt Exhaust and see if it shows any angle change when you blip the throttle (sitting still is ok).
WORKS is offline   Reply With Quote
Old 10-09-2019, 01:31 AM   #11
solidsnake11
Drives: brz
I have it on a butt dyno. Using romraider, logging, and mafscaling 2.51
Its very obvious that its low on power for ~10 pulls
Not really worried about getting every ounce of hp out of it, just wondering what the heck the computer is testing, doing the first couple of runs. I kind of figured it was the pedal learning that others have posted about.
Old 10-09-2019, 01:58 AM   #12
solidsnake11
Drives: brz
Does traction control have learning features?
Old 10-09-2019, 10:13 AM   #13
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Is there a reason you won't give us datalogs? https://datazap.me/ lets you upload them for free.
The Following User Says Thank You to DarkPira7e For This Useful Post:
wparsons (10-09-2019)
Old 10-09-2019, 11:59 AM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
YOUR INTAKE TEMP is probably around 180f or more. knock knock.
The Following 2 Users Say Thank You to chaoskaze For This Useful Post:
DarkPira7e (10-09-2019), wparsons (10-09-2019)
Search this Thread:
Advanced Search
WTB: 4" midrange speakers rva_86 Want-To-Buy Requests 0 10-23-2018 11:42 AM
Midrange speaker in dash? yomchi1989 AUSTRALIA 57 05-01-2018 09:46 PM
OEM Audio + 4" midrange upgrades ft86me Electronics | Audio | NAV | Infotainment 11 04-07-2017 08:57 PM
Open flash tablet Flat Floot shifting 7Seraph Software Tuning 1 03-11-2016 04:27 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
