10-08-2019, 12:29 PM | #561 |
Drives: Toyota 86 TRD/SE
Thanks for the suggestions. I will play with tire pressure this Sunday. It is supposed to be about 40 degrees this Sunday morning. Is it safe to drive on the Stones at that temperature or should I put them on at the event? I have heard that Stones don't like temperatures below 50.
10-08-2019, 01:13 PM | #562 | |
Drives: 2016 Scion FRS
I actually drove the first 75 miles or so in the snow on my way to the Dixie Tour a few years ago in my ES car. |
10-14-2019, 08:13 AM | #563 | |
The Following User Says Thank You to Mball19 For This Useful Post: | strat61caster (10-16-2019) |
10-16-2019, 06:25 PM | #564 | |
Custom User Title
It's when you add in environmental factors such as rain, ice, and snow that you then bring in the safety factor. A dry competition tire at its optimum temperature while being driven on ice (ignoring that there's no way you're going to pull this off) would be fractionally more effective than a tire at 0C but would not be considered safe.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
10-16-2019, 11:02 PM | #565 | |
Drives: BRZ 2017 Pure Red, MT
That's not exactly true depending on your definition of safe. Obviously the tire will not explode or fail. But it could be unsafe for the tire. R-compounds tire (or tires kinda close to it like the RE71R), can get damaged if driven in freezing condition. I think the compound gets too hard and that can create small cracks in the rubber. But above freezing temperature the tires should not get damaged. At 40F it should not be a problem. |
11-19-2019, 02:46 PM | #566 |
Drives: 2013 WRB BRZ
I pulled off the D Street Championship for the Cincinnati Region!
The Following User Says Thank You to BigTuna For This Useful Post: | radon55 (11-19-2019) |
06-30-2020, 02:30 PM | #567 |
Who has run the car both stock and with an aftermarket front sway bar? Is it really worth it?
On a 60sec course, how much time do you think can be saved by using a bigger front sway? |
06-30-2020, 04:00 PM | #568 |
Drives: 2017 Asphalt 6spd 86
I have the Whiteline 20mm. Its hard to say about specific time gains with so many factors to deal with. It does make the rear feel planted through transitions. Therefore making you faster saving time.
The Following User Says Thank You to Olegreg21 For This Useful Post: | nico_rsx (07-02-2020) |
07-02-2020, 11:50 AM | #569 | |
Are you using the whiteline adjustable end-links? Does it make the car understeer during longer sweeper/steady-state turn? |
07-02-2020, 02:10 PM | #570 | |
I wouldn't say it understeers anymore but it may with low grip tires. I'm also on koni struts so that may help the balance a little more. I run the bar and front struts on full stiff and it turns great imo. |
The Following User Says Thank You to Olegreg21 For This Useful Post: | nico_rsx (07-03-2020) |
07-13-2020, 09:03 PM | #571 | |
Drives: 2017 base 86
Current setup: oem crash bolts (was able to get -1.5 F camber) slight toeout F / slight toe in rear (but basically 0 all around) motegi wheels wrapped in Azenis rt615+ tires (32F/30R)PSI I may just start out in the softer setting as a starting point and go from there. |
07-17-2020, 09:12 AM | #572 | |
07-19-2020, 01:01 AM | #573 |
07-20-2020, 08:03 PM | #574 | |
Drives: '13 FRS - STX
If you don't have adjustable end links you'll likely put preload on the bar which may cause some thing wonky, but even then I doubt it would be super noticeable. |
Similar Threads | ||||
SCCA Solo Street Modified (SM) Discussion | whataboutbob | Tracking / Autocross / HPDE / Drifting | 61 | 07-27-2020 10:03 AM |
SCCA Solo C Street Discussion | Kido1986 | Tracking / Autocross / HPDE / Drifting | 4833 | 07-08-2020 03:52 PM |
Gen3MR2's C Street (SCCA SOLO) Progress | Gen3MR2 | Tracking / Autocross / HPDE / Drifting | 0 | 02-12-2016 01:02 PM |
2014 SCCA Solo Nationals/Pro Solo Finale thread | edj | Tracking / Autocross / HPDE / Drifting | 206 | 09-19-2014 11:34 AM |
Henry's C Street (SCCA Solo) progression | Kido1986 | Tracking / Autocross / HPDE / Drifting | 74 | 05-04-2014 08:20 PM |
