Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-24-2015, 11:57 AM | #1 |
Drives: '13 SWP GT86
What is this noise? New coilovers and LCAs, video inside
So a few days ago, I installed the following:
- D2 Coilovers - ISC Rear LCAs - Japspeed rear toe arms Now after just a few miles, this noise appeared, coming from the rear right/passenger side rear. It's only really audible when going very slowly, and doesn't seem to me to be dependent on bumps in the road. When going normal road speed, say 40+ mph, I can't hear it. So I took out the trunk liner etc and had my brother film the sound while rolling with the car turned off, downhill. [ame="https://www.youtube.com/watch?v=KFWLzkqzwGY"]VID 20150724 170312 - YouTube[/ame] Can't really figure out exactly where it's coming from, if it's the LCA, coilover or even the anti-roll bar? Since it doesnt really depend on bumps from what I gather. Or that it more or less disappears in higher speeds.. I appreciate all help I can get here!
IG @squareddesign
http://www.squareddesign.se |
07-24-2015, 12:07 PM | #2 |
Drives: FRS
have you checked all the bolts and nuts to see if they're all torqued down properly?
The Following User Says Thank You to 8R6 For This Useful Post: | sqd (07-24-2015) |
07-24-2015, 12:10 PM | #3 |
Yeah that was the last thing we did before we put the car down after mounting everything. Not that another go at it is a bad idea though!
IG @squareddesign
07-24-2015, 12:14 PM | #4 |
Drives: FRS
when you torque all the bolts/nuts, do it with the suspension loaded. you can get another jack and put it under the coilover/lca to raise it up while the car is on jackstands.
07-24-2015, 01:17 PM | #5 |
I'll definitely add that to things to try later when I have the chance
IG @squareddesign
07-25-2015, 03:46 AM | #6 |
Drives: Whiteout FRS
The noise is the same noise I had for the same LCA. The issue is that there is not enough lube in the pillowball joint. Go to your nearest auto shop and buy some lube. Grease up inbetween the joint and that rubber boot a lot. That should fix the noise.
The Following User Says Thank You to Bach415 For This Useful Post: | sqd (07-25-2015) |
07-25-2015, 08:08 AM | #7 |
That might be something, I greased them both but there's a big chance I didn't grease one of them enough. Thanks for the info, hope this is it actually!
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post: | Bach415 (07-25-2015) |
07-25-2015, 09:57 PM | #8 |
I hope so too! I used both the supplied tubes of lube, one on each of them and it was still not enough for each side. I think they need to supply minimum of 4 lube tubes to be safe.
The Following User Says Thank You to Bach415 For This Useful Post: | sqd (07-26-2015) |
07-28-2015, 08:46 PM | #9 | |
I removed the inner bolt that goes through the balljoint/whatever you call it and removed the rubber boot and greased both of them, a lot. But on the first one I removed the boot on, I saw that it had this plastic bushing-thing inside it so that the ball itself didn't do metal on metal contact in its socket. The other one didn't have this, which this photo shows. My explanation of this isn't very good, English isn't my first language Hope you who read this understand what I mean anyway!
IG @squareddesign
The Following User Says Thank You to sqd For This Useful Post: | Bach415 (07-30-2015) |
07-30-2015, 04:37 PM | #10 | |
07-30-2015, 04:54 PM | #11 |
I've sent them an email over two days ago, but no reply yet..
IG @squareddesign
07-31-2015, 10:58 AM | #13 |
I would if I was in the US, but I'm on the other side of this planet
IG @squareddesign
07-31-2015, 11:47 PM | #14 | |
The Following User Says Thank You to Bach415 For This Useful Post: | sqd (08-01-2015) |
Similar Threads | ||||
WTB: Fortune Auto 500 coilovers & PBM rear LCAs | manualmotive | Want-To-Buy Requests | 2 | 04-26-2015 09:33 PM |
PA: Part out 57xtreme 18x9.5 +40/Coilovers/LCAs/Perrin 2.5"/Whiteline | tapsumbongfrs | Wheels and Tires | 7 | 11-09-2014 11:46 AM |
Stock rims +coilovers +spacers +LCAs | ang31ito | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 04-03-2014 04:22 PM |
Inside bubbling noise | cantholdanymore | Issues | Warranty | Recalls / TSB | 6 | 11-18-2013 07:36 PM |
Strange engine noise during startup (Video inside) | StOpNG0x | Issues | Warranty | Recalls / TSB | 2 | 01-29-2013 07:24 AM |
