Old 04-13-2014, 02:44 PM   #141
TM
TM's Avatar
Drives: DGM BRZ 6MT
Great guide. Did my first oil change and it was really simple and easy.
I filled my car with 4.5 quarts of oil and checked the level, but it is past the max line. Anyone else have this problem?
TM is offline   Reply With Quote
Old 04-13-2014, 02:55 PM   #142
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I actually put in 5.5 liters which is the specified amount from the manual and when I check the level it's a little bit over the full line.
Weird
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 04-13-2014, 02:59 PM   #143
DC2R
Drives: 2014 Scion FR-S
Level should be between the two marks when cold and level
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 04-13-2014, 04:38 PM   #144
Young_makaveli
Drives: 2013 frs
Originally Posted by baldolera View Post
Nice. Don't forget to mention that you should lube up the oil filter gasket with a little oil! Now, I just hope someone posts a DIY on a Fumoto Drain Valve and a review on it as well.
The factory oil filter gasket comes already lubed from the box.
Just remove the plastic on top of the filter and install
Old 05-18-2014, 11:00 PM   #145
JoeC
Drives: Subaru BRZ Limited
The OEM one does not come lubricated out of the box. It has a thin film of grease on it probably to keep it from drying out on the shelf but it says specifically on the filter to "apply film of engine oil on gasket and tighten 3/4, after contact".
First post (and it has an image...), let's see if I screw this up, haha
JoeC is offline   Reply With Quote
The Following 2 Users Say Thank You to JoeC For This Useful Post:
chanomatik (05-19-2014), Marrk (05-18-2014)
Old 05-19-2014, 07:13 PM   #146
dreroc-z
Drives: 1989 Camaro IROC Z28
Man I thought the oil change on my 89 Camaro was a piece of cake...this looks even easier. For you guys complaining about oil getting on your hands I try to wear gloves when working on a car which really helps. Also I find that if you apply pressure inward while unscrewing the plug (by hand, after you've initially loosened it with a wrench, socket...whatever) you have more time to get your hand out of the way. Never had much luck with a downward facing filter though, even after its all drained I still have some oil come down on my hands.
dreroc-z is offline   Reply With Quote
Old 05-19-2014, 07:18 PM   #147
dreroc-z
Weird
Sorry about the double post but I think what you guys are experiencing is that the oil pan itself is full but when they rate it for maximum oil they include the amount that would also fit in the filter which is pointed down so its empty at the time when you check your oil it appears to be higher. I think that is the reasoning behind filling the filter before you actually fill up the rest but with this car and many others doing that is nearly impossible without making a huge mess. My car burns oil (being that its 25 years old) so I tend to over fill just a tad anyway.
Old 05-19-2014, 07:38 PM   #148
White64Goat
From Owners Manual:
Oil capacity
(Drain and refill 
reference*)
• Without filter 5.5 qt. (5.2 L, 4.6 Imp. qt.)
• With filter 5.7 qt. (5.4 L, 4.8 Imp. qt.)
If you changed the filter it should be 5.7 qt.
Items in (paren) are for foreign measurements.
The Following 3 Users Say Thank You to White64Goat For This Useful Post:
dreroc-z (05-20-2014), radroach (07-25-2014), RallySport Direct (05-21-2014)
Old 05-21-2014, 01:14 PM   #149
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Good info, thanks White64Goat!
Rick
RallySport Direct is offline   Reply With Quote
Old 07-23-2014, 10:42 PM   #150
arvidj
Drives: '93 MR2 Turbo
Can any one recommend a source for reasonably priced magnetic drain plugs for the oil pan, automatic transmission and differential? I see Dimple mentioned ... I think that was the name ... but that doesn't fit the 'reasonably priced' criteria.
Thanks,
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 11-08-2014, 02:19 AM   #151
OPGForce
Drives: 2014 BRZ
Thanks for the DIY. I picked up a "fumoto valve" which makes draining the oil a lot cleaner.
OPGForce is offline   Reply With Quote
Old 02-21-2015, 11:50 AM   #152
vroom4
The aa130 OEM filters have grease on the gasket from the package. That's nice
vroom4 is offline   Reply With Quote
Old 02-22-2015, 12:50 AM   #153
Marrk
Drives: Honda Fit
^^I haven't seen an OEM filter by any manufacturer for any car that didn't come with lubricant on the gasket in many a year. With mine, I still apply a little motor oil on the gasket anyway, but that's just me.
Marrk is offline   Reply With Quote
Old 02-23-2015, 09:01 PM   #154
VakaGT
VakaGT's Avatar
Drives: None
I still don't know what kind of oil to use for e85 -_-
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Oil Change Questions #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 31 06-28-2012 11:06 PM
Color Change Dark_Angle Mid-Atlantic 10 05-30-2012 02:00 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 77 04-16-2012 10:12 AM
I was able to change my pre-order. nkrein22 BRZ First-Gen (2012+) -- General Topics 23 04-10-2012 04:16 PM
Can SOA change my preorder? Zaneman BRZ First-Gen (2012+) -- General Topics 8 04-08-2012 02:06 PM
