Old 01-29-2013, 10:50 AM   #29
Visconti
Drives: 05 STi
Do you guys having anything that will increase top speed?
Visconti is offline   Reply With Quote
Old 01-29-2013, 11:04 AM   #30
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
The JDM base 86 and BRZ are 3.727 final, and so is the IS250, so you can buy either of these two to increase top speed.
41201-80050 - Ring & Pinion Gear Set, 3.727:1
41201-80052 - Ring & Pinion Gear Set, 3.909:1
from this thread:
http://www.ft86club.com/forums/showthread.php?t=7190
ZC6BRZ is offline   Reply With Quote
Old 01-29-2013, 11:07 AM   #31
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
How much will that run for?
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 01-29-2013, 11:09 AM   #32
xjohnx
Grip>Slip
xjohnx's Avatar
Would love to see a video of some full throttle runs to illustrate just how quickly it runs through each gear.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Ganthrithor (10-19-2013), Opposed (01-29-2013)
Old 01-29-2013, 12:05 PM   #33
Calum
That Guy
Drives: 2013 asphalt FRS MT
The difference wouldn't be huge, something like this would probably amount to about .25 seconds in the quarter mile. Which is a sold gain for the money, especially if you can do the install yourself. It's more about the old Smokey Yunick adage, make as much power as you can, and gear to suit. For longevity and reliability RCE seems to be happy with the power they're making, now it's time to work on the gearing.
I REALLY like this mod, it's something that no one would know was done to the car unless you tell them. It will leave a lot of people tearing their hair out.
Myles/Andrew someone asked for rpm vs speed for 60/70/80 mph earlier in the thread. I think it was missed. I'd like to see the answer as well if you've noticed. Also, what tire size are you running. IIRC you guys went a little taller when you moved to the 18's. And finally, how different is the noise level in the car?
Old 01-29-2013, 12:09 PM   #34
Racecomp Engineering
There's a chart somewhere I need to dig up and post. Myles did post rpm @ 70 earlier.
- drew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Calum (01-29-2013)
Old 01-29-2013, 01:11 PM   #35
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
IS250, IS300, and 86 share same differential size. All are interchangeable.
IS300 had an optional factory LSD, which is similar to the standard Torsen LSD found in the 86.
IS250 only has open differential from the factory.
MT comes with 3.7:1, and AT comes with 3.9:1
Some guys, including myself, have found used IS300 LSDs and dropped them in. With the release of the FRS, some people will have the option of getting a new one to install, but they're not cheap new haha.
JDKane527 is offline   Reply With Quote
Old 01-29-2013, 01:12 PM   #36
OrbitalEllipses
Drives: Attitude
- drew
Myles posted the Cusco chart on your Facebook.
Old 01-29-2013, 01:19 PM   #37
ATL BRZ
Driving Coach
ATL BRZ's Avatar
The Following User Says Thank You to ATL BRZ For This Useful Post:
bestwheelbase (01-29-2013)
Old 01-29-2013, 01:21 PM   #38
yeah...a TURBO ! hahahaha. JK.
BTW nice work on the tuning. I feel honored you even have a eyeball to view this thread.....lol...as you are the busiest guy on this forum.
tuning literally in your sleep !
Myles
Old 01-29-2013, 01:25 PM   #39
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I'm starting to like this idea. A very good mod that would be stealthy.
Grimlock is offline   Reply With Quote
Old 01-29-2013, 01:31 PM   #40
Ahh that's right. We've got another one in pdf form with more detail (it's a table). I'll either google doc it or put it on our facebook tonight.
- Andrew
Old 01-29-2013, 01:41 PM   #41
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Great work guys.
Here's autofactory's 5.1 FD.
[ame="http://www.youtube.com/watch?v=QLjVPGJKNm4"]AUTO FACTORY 86 ExhaustテストinFSW - YouTube[/ame]
illmatic is offline   Reply With Quote
The Following User Says Thank You to illmatic For This Useful Post:
SkAsphalt (01-29-2013)
Old 01-29-2013, 02:04 PM   #42
lazyluka
Drives: GT86
Originally Posted by ZC6BRZ View Post
Nope. Speedo measures tranny.
You do realise what you said contradicts itself.
If a speedo measures tranny and you modify the diff, it will offset the speedo.
Seeing as there is no error in the speedo, I would say the 86/BRZ may be using the ABS/TC sensors in the wheel's to get the speed, so modifying the driveline, apart from the wheel sizes, should not affect the speedo in any way. Of course I could be wrong, but if I was Toyota and wanted to cut cost's that's the way I would measure speed.
This is definitely a mod on my TO DO list. It will make it into more of a "Type R" kind of car.
lazyluka is offline   Reply With Quote
The Following User Says Thank You to lazyluka For This Useful Post:
ZC6BRZ (01-29-2013)
cusco final drive
Search this Thread:
Advanced Search
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
