Engine Swaps Discussion of engine swaps. |
09-18-2013, 11:11 AM | #15 |
Ridge Racerrrrrrrrr
Time to close the thread it seems.
You don't have to go home but you can't post here.
09-18-2013, 01:50 PM | #16 |
Drives: Hydra EMS Powered FRS Raven Black
Ha ha! The beauty of the FA20 is that the head package and cams are optimized for NA. This means the are aggressive for forced induction which is partly why we all can make so much power at low boost It's really not the compression ratio.
I'm looking forward to what we can do when we have some time to build up our FA20 engine program as I think there is a ton more power in the heads. |
The Following 2 Users Say Thank You to Element Tuning For This Useful Post: | raven1231 (09-18-2013), Sportsguy83 (09-18-2013) |
09-18-2013, 02:07 PM | #17 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Sounds like the pistons would be worth getting from the DIT and maybe thats about it XD
09-18-2013, 05:19 PM | #18 |
That Guy
Drives: 2013 asphalt FRS MT
If you're investing in pistons, removing the engine, yadda yadda yadda, I doubt it would be worth it to use OEM parts. The cost difference, if there is any, of good forged pistons would be more then worth it for the extra strength. Especially if Visconti is tuning your engine.
09-18-2013, 06:54 PM | #19 |
Drives: 01 RS, STI V6 RA Limited, BRZ
Guys. The starter is on the wrong side of the block. Only the BRZ/FRS engine has the starter on the passenger side. ALL other Subaru engines have it on the driver side.
09-18-2013, 07:11 PM | #20 |
Drives: 2013 "AVO Orange" FR-S
The main point is, you won't have an cost-effective upgrade path to a turbo by putting a 2014 Forester Turbo motor in. The turbo assembly itself won't fit, so you'd be going with an aftermarket turbo kit anyways. The turbo long block would cost more than mildly beefing up the current motor with pistons/rods/bearings.
And the 2014 FA20DIT is new enough that we don't know if it can even take more power than the FA20 in the BRZ/FR-S. Too many possible issues, not many possible gains. |
09-18-2013, 07:20 PM | #21 |
The Based God
Drives: 87 Supra, 92 240SX, 13 BRZ Turbo
Fuck it, I'm swapping in a GT3 cause yolo and unobtanium amounts of money.
Milltek Full Exhaust (Overpipe, Cat-delete, Catback), AVO Turbo kit , Perrin Crank Pulley , ACT Clutch Kit , ACT Prolite Flywheel 10.5lb , Axel-Exchange Driveshaft, Sparco Assetto Gara 17x7.5, Hankook Ventus V2s 225/45/17, Michelin Pilot Super Sports 225/45/17, Rally Armor Mudflaps, Viscontiproof tune Courtesy of Drift Office LLC
The Following 3 Users Say Thank You to InvalidJohnny5 For This Useful Post: |
09-18-2013, 08:16 PM | #22 |
However you may be able to use the FRZ shortblock in conjunction with the rest of the DIT engine bits if you really wanted to go that far...
09-18-2013, 09:06 PM | #23 |
I haven't looked that closely, but doesn't the starter bolt to the transmission bellhousing and not the engine?
09-18-2013, 09:43 PM | #24 |
Drives: AE86, 2x GT86, TE27
09-18-2013, 10:47 PM | #25 | |
Seņor Member
On a related note, are there upgraded direct injectors available for the subaru system? Or would you be stuck with the power that the stock injectores maxed out at?
1974 TA22 Celica
2013 86 GT |
09-19-2013, 01:47 AM | #26 |
Drives: GT86
I highly doubt the di setup is any different.
BTW long engine is around $5k from Japan. Would be my choice if I wanted a proper turbo engine. Designed to produce 300bhp for 100k+ miles with full boost from about 1500 rpm! |
09-19-2013, 07:43 AM | #27 | |
It is different fuel injection, no port Fuel injectors, no D4-S. This engine is the reason Subaru agreed to build the twins, they wanted DIT bad and Toyota gave them the tools to develop it. It is a very good engine, what should be in our twins. And I agree this will be the defacto turbo upgrade in a few years, notice the quick defensiveness from the largest FA20 aftermarket turbo sponsor on here. I personally can't wait until swap kits start being developed.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
09-19-2013, 07:56 AM | #28 | |
I Love custom Turbo kits
Drives: Limited BRZ
(Unless you can show me a video where Subaru VP or Engineering Manager or such stated this). Also, how do you know AVO is the biggest turbo sponsor? Again need facts to prove it. You posts are misleading sometimes. The only reason AVO is commenting here is because they already looked into it.... And that is a fact
Similar Threads | ||||
SUBARU 4Pot Calipers "Bremboed" Direct Bolt On- SD, CA CHEAP! | virjose | Brakes, Suspension, Chassis | 32 | 07-12-2013 12:40 PM |
RallySport Direct's Eat, Greet, Swap Meet 2013 | RallySport Direct | BRZ Photos, Videos, Wallpapers, Gallery Forum | 3 | 05-14-2013 04:31 PM |
RallySport Direct Eat, Greet, Swap Meet 2013 Edition!! | RallySport Direct | Southwest | 9 | 05-13-2013 06:46 PM |
RallySport Direct Eat, Greet, Swap Meet 2013 Edition!! | RallySport Direct | Southwest | 0 | 04-03-2013 11:04 AM |
RallySport Direct Eat, Greet, Swap Meet 2013 Edition!! | RallySport Direct | Rocky Mountains / Great Plains | 0 | 04-03-2013 11:04 AM |
