05-06-2013, 06:53 PM | #239 |
Drives: 2013 FR-S Whiteout 6MT
Had the dealer service the oil leak two weeks ago. I've only put about 300 miles on the car because of all the rain the last couple of weeks, but no leaks yet. The plate feels like it was totally degreased, so maybe carefully degreasing both surfaces is the key to getting good adhesion of the sealant.
05-09-2013, 02:11 PM | #240 |
Drives: '13 BRZ TLM Spec
2013 BRZ 6MT
Build Date: 3/23/2012 Current Mileage: 15,000 Recently started smelling burnt oil. Right Rear cam plate, dry as a bone. Front timing cover (passenger side), not so much. Pics to come...
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
05-09-2013, 07:42 PM | #241 |
Dry rear cam plate:
Wet lower front timing cover:
05-09-2013, 10:17 PM | #242 |
Drives: 2013 Asphalt FRS
hmmmmm going to check my car in a few
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
05-16-2013, 12:41 PM | #243 |
We could cnc machine a plate with a dual viton o-ring grooves. I'm going to check our car to see if we are having the same problem.
Please respond if you would be interested in a billet aluminum cam plate. Thanks! |
05-16-2013, 12:55 PM | #244 |
Drives: 2013 FR-S, Black 6 Speen Manual
05-16-2013, 01:05 PM | #245 | |
Proud of BOXER
Drives: Subaru Boxer
OMG, yes please!
05-16-2013, 01:45 PM | #246 |
Drives: 2016 Toyota 4Runner Trail Premium
interested for sure.
05-16-2013, 01:49 PM | #247 |
Drives: '15 STi Ltd
The Following User Says Thank You to Chimpo For This Useful Post: | norsamerican (05-16-2013) |
05-16-2013, 03:17 PM | #248 |
No oil leaking from our car but I only have 2,000 miles on it. It appears our plate has a large bead of silicone around the whole perimeter. We have the plate off and are going to see if an o-ring solution will solve the problem.
05-16-2013, 05:32 PM | #249 | |
This is an easy $75 per plate for you that most anyone will buy until OEM TSBs it with a new part.
The Following User Says Thank You to Dezoris For This Useful Post: | charged86 (06-02-2013) |
05-16-2013, 05:35 PM | #250 |
Drives: WRB BRZ
Dealer cleaned the plate off last week I'm keeping an eye on it.
05-16-2013, 06:11 PM | #251 |
Drives: '15 STi Ltd
My opinion is that it's the gasket between the two halves that provides the leak path. You can see it in the factory sealer.
05-16-2013, 07:08 PM | #252 |
Drives: Moped
If Toyota can't figure this out soon enough, I would be interested...
Similar Threads | ||||
Still Leaking? | 636 | Issues | Warranty | Recalls / TSB | 15 | 01-11-2013 03:41 PM |
Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 04:43 PM |
Leaking front left shock | Xauterus | AUSTRALIA | 10 | 11-06-2012 04:15 PM |
Tires keep leaking | EvoXDD | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-29-2012 03:03 AM |
Brake Light Leaking Covered in Condensation | Smokinbuffalo | BRZ First-Gen (2012+) -- General Topics | 9 | 06-12-2012 04:43 PM |
