Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-18-2019, 10:55 PM | #1 |
Drives: BRZ, Sport Tech, World Rally Blue
woosh sound at 3000 rpm
Hey all,
I own a 2013 BRZ which I've had since new. Lately I have noticed a (pardon the poor description) a momentary Whoosh sound at approx 3000 RPM. This occurs in all gears and is quite loud when the engine is cold and diminishes as the engine warms up. I cant imagine that I would not have heard this in the past. This sounds deliberate. Does anything in particular happen at 3000 RPM ? Could this be an Exhaust thing ? or Transmission ? Sound does not occur in neutral only when in gear and moving. By momentary I mean about 1 sec in duration. Recently had an oil change I don't know if the sound was there before that. O.K. Thats All the facts I have. All opinions welcome Thanks |
06-18-2019, 10:56 PM | #2 |
Rust bucket enthusiast
Is it at full throttle, or regardless? What transmission do you have? What modifications do you have done, if anything?
06-18-2019, 11:01 PM | #3 |
Could be the sound tube, which channels intake noise into the passenger side footwell. To me, it does sound like swoosh sound (i like it a lot haha)
06-19-2019, 09:19 PM | #4 |
Thanks for your quick replies,
1) The sound occurs at 3000 rpm when accelerating normally. 2) This is a 6 speed Standard Transmission. 3) The car is stock with No modifications. |
06-19-2019, 09:30 PM | #5 |
Drives: 2014 BRZ Limited, Satin White Pearl
Would it be possible to record this sound and post a video?
10-17-2019, 03:02 PM | #6 |
Solved
Thought I'd get back to all with the solution to this issue.
As this was more a nuisance than anything else I finally got around to actually taking this to my local mechanic for a look see. After about a 30 second ride with me in the car my mechanic announced " I know what that is" Directly above the exhaust pipe about midway down the car there is a heat shield. This shield is just millimeters above the pipe. In my case the shield had broken / rotted or otherwise come loose. During acceleration and at a specific resonance. the broken shield would temporarily vibrate causing the Wooshe sound. Once the vehicle heated up and all the metals expanded. the sound dissipated. The final solution was a $3.00 hose clamp placed around the pipe and shield. My Mechanic didn't even charge me for the effort. All is now well Thanks for all your comments Tanto |
The Following 4 Users Say Thank You to Tanto For This Useful Post: |
10-17-2019, 03:08 PM | #7 |
Glad you got it figured out! Sometimes the easiest thing to do with a car is just enjoy the nuances. If you let every little thing get to you, you may forget to enjoy the other 98% of the car
Good rule of thumb is that if there's any weird sound that happens during acceleration only start with the exhaust |
Tags |
3000, cold, sound, whoosh |
Similar Threads | ||||
Axle clicks and woosh woosh rotational noise | mhiscott | Engine, Exhaust, Transmission | 2 | 07-29-2018 05:57 PM |
Woosh sound 2017 86 | Qc86 | Issues | Warranty | Recalls / TSB | 9 | 03-15-2017 12:18 AM |
Strange woosh sound on some start ups | Stefanchrstn | Issues | Warranty | Recalls / TSB | 6 | 04-16-2016 06:14 AM |
Can't Get Over 3000 RPM | ButtonMasher | Issues | Warranty | Recalls / TSB | 26 | 09-11-2014 08:40 PM |
3000 mile review. | Superhatch | BRZ First-Gen (2012+) -- General Topics | 7 | 06-18-2012 10:33 PM |
