Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-07-2017, 12:33 PM | #29 |
Drives: 2014 GT86
I'd have nothing wrong with brake squeel on track. Funnily that's the place one can bed in even most track-ish pads .
But i wouldn't want squeel on daily driving. Maybe other drivers on the road don't mind as much as i think they do, but at least i feel like idiot stopping with loud squeel near them at stoplights or squeeling madly on every small stop when moving in traffic jams. And daily driving is what 99% of my milleage is made of. So certainly i mind squeeling in general, ease of bedding pads when daily driving, and as due being too lazy and using same pads on both DD & track, am willing to give up some of 1% track-only performance to keep ability to DD bed. For me track days are more for fun, not competition anyway. If i'll ever follow further down rabbithole and will become more of a track junkie, most probably will need to go pad-swap route, to get both performance & reasonable daily driving properties. As it seems, there are no ideal pads that will fit best for all usage cases, every is compromise of sorts and one just have to choose his own poison depending on priorities .. or swap between sets. |
02-07-2017, 08:53 PM | #30 |
Drives: 2013 Firestorm FR-S
Haha TBH I'm with you guys, I don't care that much about the squealing and chirping but was worried it it might have been a larger problem with the pads. Once I put on the GS1 I didn't need to go back to the R12/10.0 Also wanted to keep the R12/10 'track only' to keep better tabs on their wear.
Squealing is cosmetic. I dont think the rotational chirping was good for the brake system though.
02-07-2017, 10:41 PM | #31 |
I get chirping after my pads warm up when driving (while not on the brakes), especially when it's bumpy. I already lubed the slider pins with 3M silicone lube and used a wire brush to clean off the brackets that the pads slide in to. the chirping is still there though... gonna take another look at it soon and see what else I can do. I'm thinking it has to be that bracket since the caliper slides easily and freely.
02-08-2017, 12:03 AM | #32 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
07-22-2017, 11:51 PM | #33 |
Drives: 2013 SWP BRZ
@drewbot any update on your rotational noise?
I'm trying to troubleshoot a similar squeal on my HC+800s; rotational squeal at low speeds when coasting/light throttle. Already had pads cleaned and caliper wire brushed and re-lubed (even sanded the lip off my rotor edges) by a dealership tech and that only solved the noise for a week or two. I dgaf about squeal but I'm worried about dragging the rears like CSG Mike suggested (fronts are and always have been dead quiet). Slide pins are the next thing on my list to check. Maybe check/clean pistons and boots too? *shrug* Just wondering if you had any more info towards a resolution instead of making another goddamn "my brakes are squealing" thread. Sent from my Pixel using Tapatalk Last edited by KL; 07-23-2017 at 10:30 AM. |
02-14-2018, 01:26 PM | #34 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Similar Threads | ||||
Brake Squeal | Maritime Storm | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 03-01-2015 10:59 AM |
How much benefit are lighter wheels rotational mass wise | Sportsguy83 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 01-05-2015 08:34 AM |
No squeal pads for AP Racing Essex Sprint Kit | Hags86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 04-04-2014 03:53 PM |
Blower fan squeal | 2point0 | Issues | Warranty | Recalls / TSB | 4 | 04-01-2014 07:40 PM |
No Squeal Track Pad? | gbgracer | Tracking / Autocross / HPDE / Drifting | 15 | 03-27-2013 08:21 PM |
