Old 10-23-2023, 08:32 PM   #99
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Simple Fastening System for Front Fascia
I installed external fasteners to my front fascia so the snap-together attachment point to the fender would stop popping apart.
I have a good-sized splitter on the front and the car lowered, and the fascia has been on and off a lot. This fix lets me stop using duct tape to hold the joints together.
Install is easy:
Just remove the fascia and remove the black plastic clip block on each of the fenders by removing the two, recessed #6 bolts. There is one clip that should be squeezed to get it to release. Put the block in place on the fascia and transfer the two bolt hole locations to the facia, and drill holes for longer 6mm bolts. I used 50mm flat-head bolts and countersunk aluminum washers. The tapered aluminum washers are only 1/8" thick. Both pieces of hardware are from McMaster-Carr. Bolts can be bought in a light blue zinc coating. I darkened the heads.
The two longer bolts sandwich everything together using the existing fender nuts.
It's not quick release but it's close, it looks good, and I won't have to worry about the front of the car coming loose again while on track or if I bump a curb or have an off-road excursion.
Scargod is offline   Reply With Quote
Come track with the Nor Cal 86 Drive Challenge in 2022 Sachmet43 Northern California 1 05-07-2022 12:52 AM
glamcem's Track Build 2022 BRZ (a new chapter) glamcem Member's Car Journals 9 05-02-2022 10:41 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) -- General Topics 20 02-10-2022 11:44 AM
In Northern CA? Come track with us in 2022! Sachmet43 Tracking / Autocross / HPDE / Drifting 13 01-15-2022 10:36 AM
