Forced Induction Turbo, Supercharger, Methanol, Nitrous |
02-17-2014, 07:55 PM | #1 |
Drives: White 2014 BRZ
Why all the "big" turbo kits @ low boost
Why is there no 300whp max turbo kits out there? Or is there? Seems silly to run 10 psi on a 25+psi capable turbo. All you are is enjoying lag and barely in the turbo's efficiency range...
I'm looking for a 16g/18g sized kit where are they? |
02-17-2014, 07:58 PM | #2 |
Full Blown has a nice list of Turbos that are optional that you can upgrade to. Most of these units can be tuned for more power, but without internals there is a limit. Of course we can throw a big turbo on it, and just let it ride, but I'm sure you don't want a blown motor of course.
Just another reason why full blown has several turbo options instead of just one or two set turbos. Some guys want the option to upgrade later down the road when they do want internals, some guys are just looking for 300rwhp and be done with it. |
The Following User Says Thank You to ModBargains.com For This Useful Post: | stevo585 (02-17-2014) |
02-17-2014, 07:59 PM | #3 |
King of Kiwi Palace
Drives: Faster than you
I hope this is a troll post.
The Following 18 Users Say Thank You to Ironsquid For This Useful Post: | cdrazic93 (02-17-2014), Dipstik-sportech (02-17-2014), ecko04 (02-17-2014), ftc~brz (02-20-2014), hmong337 (02-17-2014), jamesm (02-17-2014), jimmy4thenguyen (02-18-2014), lbroskee (02-18-2014), Mad1723 (02-22-2014), MAPerformance (02-18-2014), MikesFRS (02-22-2014), NickFRS (02-18-2014), SirBrass (02-17-2014), SnapOv3st3r (02-17-2014), sosick (02-20-2014), Sportsguy83 (02-17-2014), SubiePig (02-18-2014), woode (02-17-2014) |
02-17-2014, 07:59 PM | #4 |
First 86 Driver Baby!
Drives: FR-S, Flex
My kit is running 16psi with approximately 325 whp (Treadstone kit with BW 6258 EFR turbo).
02-17-2014, 08:09 PM | #5 |
Junior
Drives: a car
Boost is pressure. Pressure on internals not designed for added pressure = boom, OR rod to the knee.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | Astroboy (02-28-2014), DriftEightSix (02-18-2014) |
02-17-2014, 08:09 PM | #6 |
Drives: Sterling BRZ Ltd
There are benefits to running a larger turbo on less boost. PSI is a measure of pressure not volume, so say 10psi on a little turbo is not the same volume as 10psi from a large turbo.
Also if you have to wring out a little turbo to make that 10psi it is going to introduce more heat into the charge then a big turbo that doesn't have to work as hard. So a street car running pump gas and daily running around it can be advantageous. If you want a smaller turbo kit look at the AVO or Greddy
The Following 9 Users Say Thank You to mrk1 For This Useful Post: | 1stGenBRZ86 (02-17-2014), ftc~brz (02-20-2014), Hanni_0176 (02-17-2014), Ironsquid (02-17-2014), Ryan P (02-18-2014), SirBrass (02-17-2014), sosick (02-20-2014), Sportsguy83 (02-17-2014), stevo585 (02-17-2014) |
02-17-2014, 08:12 PM | #7 | |
I Love custom Turbo kits
Drives: Limited BRZ
now, the "big" turbos on low boost are not proving to be too laggy. There are benefits to them as already said, lower charge temps, more HP per psi, etc.
02-17-2014, 08:14 PM | #8 | |
beyond that, you have the overhead to produce craaaaaazy power on e85 should you choose to. larger turbos are also easier on drivetrain parts, as they tend to ramp in the torque curve more progressively than a smaller turbo. lots of immediate torque at low rpm does little more than turn tires into vapor and break stuff. so there are lots of reasons, and having bought a 'small' turbo (gtx2867r) and tuned larger ones, i'll be swapping mine out for something much larger very soon. the benefits far outweigh any perceived drawback, most of which are just a consequence of applying common knowledge that doesn't apply to the fa20. this engine breaks rules. |
The Following 9 Users Say Thank You to jamesm For This Useful Post: | Hanni_0176 (02-17-2014), Ironsquid (02-17-2014), King Tut (02-18-2014), mrk1 (02-17-2014), OjiGeorge (02-18-2014), SirBrass (02-17-2014), Sportsguy83 (02-17-2014), stevo585 (02-17-2014), TRD_07 (02-17-2014) |
02-17-2014, 09:03 PM | #9 |
Junior
Drives: a car
*sniff* *sniff* do I smell a GTX4294R? I hope so lol jk. I think he likes traction and an engine that works without retard timing...lol
02-17-2014, 09:06 PM | #10 |
The Following User Says Thank You to jamesm For This Useful Post: | Sportsguy83 (02-17-2014) |
02-17-2014, 09:12 PM | #11 |
Junior
Drives: a car
Lets see, 3582, more overhead, although the 3076 provides quite a bit of overhead itself, both sound like jet engines...3076 may spool earlier, i think? the 3076 sounds like a better all around option to me.
02-17-2014, 09:14 PM | #12 |
King of Kiwi Palace
james you can have my 35r im done with it, too small, going 42101 twin scroll
The Following 2 Users Say Thank You to Ironsquid For This Useful Post: | jamesm (02-17-2014), Sportsguy83 (02-17-2014) |
02-17-2014, 09:15 PM | #13 |
3576 then, I was just looking myself
The Following User Says Thank You to mrk1 For This Useful Post: | Jetscape (02-18-2014) |
02-17-2014, 09:17 PM | #14 |
That's what I'm thinking, but id hate to have to upgrade again .
Similar Threads | ||||
!!!Limited time only sale on Greddy Turbo Kits with Free Boost Gauge!!! | vividracing | Forced Induction | 0 | 01-24-2014 01:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
Turbo Kits: Rational boost threshold yet? | Ryephile | Forced Induction | 88 | 01-22-2013 12:05 AM |
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 02:53 PM |
