10-17-2019, 02:09 PM | #5153 | |
Stay away from the DW 65C. DW 300C is totally fine (and is what I use). PM for the FF setup. |
The Following User Says Thank You to CSG Mike For This Useful Post: | sroby (10-19-2019) |
10-17-2019, 03:54 PM | #5154 |
Drives: '14 BRZ Limited
10-17-2019, 04:35 PM | #5155 |
Drives: Q5 + BRZ + M796
What type of belt do you have? Are you doing hard launches or downshifts? How is the tension on the belt? Is it tight enough? If you push on the belt in an open area, how far does it move?
10-17-2019, 05:02 PM | #5156 | |
Also, as my friend's fiance put it: "damn guy, you downshifted while I was putting on mascara and I didn't feel a thing". I may not be the fastest guy on track, but my heel-toe is good. However, if the downshifts are causing it I can stop doing it. The belt is tight, there is minor movement on the alternator side and a bit more movement on the AC\water pump side considering the distance of the pulleys. The belt doesn't look bad to me, but you guys may have a different opinion. It's fine at the top: And it shifts here, at the bottom on the fluid dampr and the water pump pulley it's shifted 1 rib. Should I get a new belt? What else can be causing it? |
10-17-2019, 05:23 PM | #5157 | |
Edit: It is ribbed on both sides, right? It is hard to tell.
10-17-2019, 05:26 PM | #5158 |
The Following 3 Users Say Thank You to peaches For This Useful Post: |
10-17-2019, 06:20 PM | #5159 |
What are all the pulleys you have?
10-17-2019, 06:33 PM | #5160 |
10-17-2019, 08:14 PM | #5161 |
You think those are on solid?
10-17-2019, 08:51 PM | #5162 |
I'm going to say yes, the Perrin pulleys have been on for over 3 years and haven't had an issue. The fluid dampr was installed by the guy that did my crap tune, I just checked it and there is no play on it. When I tried to tighten the bolt the ratchet didn't move.
The noise only started this week, not sure if it shifted before that. Next time I drive it I won't do the regular downshifting and see what happens. Just did some free revs in the garage and it's still in place. Sent from my Pixel 2 using Tapatalk |
10-17-2019, 10:05 PM | #5163 | |
10-18-2019, 07:22 AM | #5164 | |
10-18-2019, 03:07 PM | #5165 | |
pessimistic skeptic
https://www.amazon.com/gp/product/B000UO8MAG You need double sided belt I wouldn't use that one sided Goodyear belt in the picture. |
10-19-2019, 12:11 AM | #5166 |
Drives: 2015 Firestorm 08/05/15
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
