Software Tuning Discuss all software tuning topics. |
12-09-2019, 06:15 AM | #1 |
Drives: turbo frs
AFTER FLASH 03TIMES
DEAR steve and all
i have flash oft rom of ZA1JD00C US MY15 6MT throw tactrix openport 2 it download ok the stock rom to car ECU secound i try rom ZA1JA01G stage 1 also downloaded ok to ecu but i try to download again other rom ecuflash gave error msg i try to upload and download not except at all what colud be the issue ??? thnx |
12-09-2019, 09:13 PM | #2 |
Drives: FT86
Take a screenshot of the ecuflash\tactrix logging screen
Make sure ignition full on not just accessory Wait 15 seconds after you tirn ignition full on before trting to read or write to ecu Make sure battery volts with ignition on is 12v or more Reboot pc Check cavles and obd port Try bending both rows of pins on the tactrix adapter inwards very slightly use al old full size SD memory card or similar. |
The Following User Says Thank You to steve99 For This Useful Post: | gt7877 (12-10-2019) |
12-10-2019, 05:42 AM | #3 | |
Drives: turbo frs
Similar to this image http://s644.photobucket.com/user/agr...p6dlm.jpg.html I removed driver of openport I change tactrix adapter by new one Both gave same error |
12-10-2019, 05:43 AM | #4 |
Drives: turbo frs
12-10-2019, 07:05 AM | #5 |
Drives: turbo frs
12-10-2019, 07:49 AM | #6 | |
Drives: FT86
Are you using tactrix version 2.0 hardware ? As in fhat picture its version 1.3 the older tactrix will not work with bz\86. Also male sure you select brz as vehicle in ecuflash. If it doesnt even read the VIN or the ecu calibration id calid then its almost certianly an obd port connection issue with car. Even on a ecutek flashed ecu tactrix will still read vin and calid. Try testing tactrix on differnt car i think it obd port of car |
12-10-2019, 11:58 PM | #7 |
Drives: turbo frs
Hi Steve
That image just for the same issue I have 2 adapters Openport 2.0 It's read Vin and cid But cannot write or red after flashing 03 times |
12-11-2019, 03:57 AM | #8 | |
Drives: FT86
Ok if it reads vin and calid the connection is provably ok. But if you can do a test read on another car to check tactrix would be good. I assume ecu has not ben locked by ecutek or BRZEdit ?. And car starts and runs fine ? try removing battery terminal for 30 minutes, then replace connection, then try flasging at first turn on of ignition |
Similar Threads | ||||
SOLD: Open Flash Tablet, Open Flash Header, Crawford Power Blocks | Totemo_Hayai | Engine, Exhaust, Bolt-Ons | 14 | 09-15-2019 02:28 AM |
My experience with Shiv & his products at Open Flash Tablet / Open Flash Header | TouchMyHonda | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 10-23-2015 09:57 AM |
FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
