05-04-2014, 12:24 AM | #1513 | |
Sent from my SGH-T599N using Tapatalk |
05-04-2014, 02:27 PM | #1514 |
Manny
Drives: 13 WRB Brz
WTB:
-smoked side markers -sti style front lip (think thats the one where the side edges curve up) in polyurethane material -borrow/rent oem tail lights for a couple of weeks while I smoke mine out Sent from my iPhone using Tapatalk
05-06-2014, 10:33 AM | #1515 |
Drives: 13 Brz Jrsc
Bayson R cs style front lip. $60
05-06-2014, 01:12 PM | #1516 |
05-06-2014, 01:13 PM | #1517 |
Attachment 77598 anyone need heat wrap for headers or oil pan? @BigFatFlip
05-06-2014, 03:58 PM | #1518 |
Drives: DGM BRZ
Selling:
3 Stock Michelin Primacy HP Tires 7/32 tread left $100 obo. Located in San Ramon.
05-06-2014, 09:36 PM | #1519 | |
Drives: FRS(sold), AP2, R35, FJC, ED9
I might. How much? Temp specs?
05-06-2014, 09:39 PM | #1520 |
How much for the license plate?? Awesome plate.
05-06-2014, 09:58 PM | #1521 |
05-07-2014, 05:35 PM | #1522 |
Drives: Red
FS: j2 exhaust flange scrape, scratches here and there $250obo, and i also have borla el headers for $250obo...located in stockton..
05-07-2014, 05:36 PM | #1523 |
STX 188
I have an used GoPro HD Hero 2, outdoor edition, it's in great shape for how much usage it's been through. I've only used it for autocross pretty much, never been under water or anything. I drilled a hole on the side of the case to fit a mic through it.
I upgraded to the 3+ black so I no longer need this. I have an additional GoPro battery that comes with the purchase at asking price, $150. I also have an used LCD BacPac for $40. Works with the Original HD and HERO2. Outdoor edition comes with a vented helmet strap, head strap, 2 curved and 2 flat surface adhesive mounts and a 3-way pivot arm. Camera Optics Lens Type: Fixed Focus (2ft/0.6m - ∞), glass Aperture: f/2.8 (high performance in low-light situations) Angle of View: 170° wide angle available in all modes Angle of View: 127° medium angle in 1080p, 720P, or WVGA mode Angle of View: 90° narrow angle in 1080p or 720P mode Video HD Video Resolution Modes: 1080p = 1920x1080 pixels (16:9), 30 fps 960p = 1280x960 pixels (4:3), 30 fps or 48 fps 720p = 1280x720 pixels (16:9), 30 fps or 60 fps WVGA = 848x480 pixels (16:9), 60 fps or 120 fps Sensor Type: 1/2.3" HD CMOS Light Sensitivity: Professional low-light sensitivity (>0.84 V/lux-sec) Video Format: H.264 compression, saved as Windows- and Mac-compatible MPEG4 (.mp4) file Exposure Control: Auto with user-selectable center-weighted average and spot-metering settings White Balance: Auto Audio Microphone: Built-in, mono with AGC (Automatic Gain Control) External Input: Stereo 3.5mm jack Audio Format: 48 kHz, AAC audio compression Still Photo Resolution: 11 megapixel, 8MP, or 5MP Capture Modes: Single shot; photo every 0.5, 1, 2, 5, 10, 30, or 60 seconds; 10 photo burst; self-timer Storage Memory: SD card (SDHC), up to 32GB capacity (not included) Average Recording Times (using 32GB SD card): 1080p (30 fps): 4h 960p (30 fps): 5.5h 720p (60 fps): 4h 720p (30 fps): 6h WVGA (120 fps): 4.5h Camera Connectors & Cables PC Connection: USB 2.0 (data connection and battery charging) HDTV Out: Mini-HDMI TV Out: NTSC and PAL composite port PC Compatibility: Windows® Vista or Windows® 7; Mac OS® X 10.5 and later Power & Battery Battery Type: Rechargeable 1100 mAh lithium-ion Battery Life: Approximately 2.5 hours Charging: via USB to computer or to power adapter (adapter not included) Charge Time: 80% capacity after 1 hour from AC or DC source (requires adapter, not included) or 2 hours from USB port Waterproof Camera Housing Depth Rating: Up to 180 feet / 60 meters Construction: Polycarbonate with stainless steel hardware Size and Weight Dimensions (H x W x D): 1.6" x 2.4" x 1.2" (42mm x 60mm x 30mm) Weight: 3.3 oz (94g) including battery / 5.9 oz (167g) including housing BacPac comes with different mounts for the back. |
05-07-2014, 05:45 PM | #1524 |
JDM JUNKY
Drives: NSX
if that plate is real, gangsta
05-07-2014, 05:47 PM | #1525 |
STX 188
It's not.
05-07-2014, 06:07 PM | #1526 |
Drives: Yes
Pretty sure it's shopped
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Similar Threads | ||||
NW Marketplace v1.0 (CLOSED) | DarrenDriven | Northwest | 2872 | 08-14-2015 02:48 PM |
Looking for another Local FRS/BRZ! | XR4OUTCAST | Mid-Atlantic | 18 | 11-09-2012 02:20 PM |
MCM FR-S now in NorCal!!! | microcarmag | Southern California | 6 | 07-01-2012 06:01 PM |
2nd BRZ in NorCal? | Chauntalei | BRZ First-Gen (2012+) -- General Topics | 15 | 05-29-2012 09:44 AM |
Marketplace | GenkiElite | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 02-08-2012 03:26 PM |
