Old 05-22-2015, 04:08 PM   #71
raven1231
Looks fucking sick! Can't wait
WORKS (05-30-2015)
Old 05-22-2015, 06:44 PM   #72
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Originally Posted by flippy View Post
pics of exhaust headers under the car please =)
Here you go flippy.
WORKS is offline   Reply With Quote
The Following 2 Users Say Thank You to WORKS For This Useful Post:
flippy (05-24-2015), Trefoil (06-29-2015)
Old 05-22-2015, 08:05 PM   #73
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Are all the exhaust components ceramic coated? Will there be a thermal blanket to go over the turbo? I see that there's a heat shield between it and the battery, but that location for the turbo has me worried...
Either way, hope the CARB papers get thru!
Old 05-26-2015, 12:50 PM   #74
WORKS
WORKS's Avatar
Thank you for the encouragement.
No turbo blanket is included because it's not necessary.
Our turbo kits' up pipe and downpipe are both ceramic coated on the inside and outside. This helps cut down on radiant engine bay heat significantly. We run a battery heatshield (included in the kit) and have monitored battery surface temperatures after track sessions and have found them to be a non-issue when using the heatshield. We did see some slight heat effects on the thin plastic battery tray after extended track sessions so we redesigned our heatshield to cover the tray as well. The injector ECU showed no heat effect. We provide thermal wrap in our kit to protect all wiring in the area of the turbo.
Hope that helps, cheers.
BigFatFlip (05-26-2015), HachirocksU (11-13-2019)
Old 05-26-2015, 10:56 PM   #75
FR-Sizzle
Drives: brz
If this replaces the factory over pipe then how will this pass carb
FR-Sizzle is offline   Reply With Quote
The Following User Says Thank You to FR-Sizzle For This Useful Post:
Clipdat (05-29-2015)
Old 05-27-2015, 01:04 AM   #76
raven1231
I'd assume since all the emissions equipment is still intact.
The Following 3 Users Say Thank You to raven1231 For This Useful Post:
CSG Mike (05-27-2015), tahdizzle (06-01-2015), WORKS (05-27-2015)
Old 05-27-2015, 01:38 AM   #77
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
There is nothing in the overpipe. The cats are in the header and front pipe.
The Following 3 Users Say Thank You to boredom.is.me For This Useful Post:
CSG Mike (05-27-2015), hmong337 (06-23-2015), WORKS (05-27-2015)
Old 05-27-2015, 07:29 PM   #78
WORKS
WORKS's Avatar
Another view of how the intercooler radiator is mounted.
The Following User Says Thank You to WORKS For This Useful Post:
raven1231 (05-27-2015)
Old 05-28-2015, 04:29 PM   #79
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
numbers numbers numbers @WORKS! haha =)
stoked_on_spool is offline   Reply With Quote
The Following User Says Thank You to stoked_on_spool For This Useful Post:
WORKS (05-28-2015)
Old 05-29-2015, 01:39 PM   #80
raven1231
I know lol every time I see an update I hope its that
WORKS (05-30-2015)
Old 05-29-2015, 02:03 PM   #81
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I believe that he is referring to the fact that per CA law, technically any modification of the exhaust system BEFORE the last catalytic converter is not CARB legal and is grounds to fail a SMOG inspection. So even if I just throw in a Motiv Concepts overpipe and leave the rest of my exhaust intact, it's still no bueno.
Again, as dumb as it sounds, even though it's just replacing one overpipe with another and retaining both factory cats, it's technically still not street legal. Hopefully they'll "do the right thing" and make this kit CARB legal though.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
FR-Sizzle (06-02-2015), raven1231 (05-29-2015)
Old 05-29-2015, 08:52 PM   #82
WORKS
WORKS's Avatar
Here you go.
As noted in the image, our WORKS Air Filter, Front Pipe, Mid Pipe & Axle Back Muffler were installed at the time of the Stage 2 readings.
The Following 6 Users Say Thank You to WORKS For This Useful Post:
BigFatFlip (05-30-2015), GhostOp86 (05-29-2015), hmong337 (05-30-2015), illmatic (05-30-2015), raven1231 (05-30-2015), stoked_on_spool (06-01-2015)
Old 05-30-2015, 01:50 PM   #83
GhostOp86
Fr-s Whiteout
GhostOp86's Avatar
Drives: 2017 civic type R #1353 2017 ss1le,
Looking good WORKS. cant wait till cam tunes out my car. Here you go guys just in case you are curious.
Turbo Fr-s 2013 Cam Tuning SOLD
http://youtu.be/3vM-2MijcQQ
2017 ss1le
2017 Honda Civic Type R #1353
2002 Rsx Type s
GhostOp86 is offline   Reply With Quote
The Following 2 Users Say Thank You to GhostOp86 For This Useful Post:
raven1231 (05-30-2015), WORKS (06-01-2015)
Old 05-30-2015, 01:58 PM   #84
raven1231
I can't wait for that either bud! Any idea when ?
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 12:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
