10-27-2014, 08:18 AM | #29 |
I think this is true for me too. I'm used to the clutch, but the throttle pedal has a dead spot in the first 5% of movement.
2022 BRZ Build 2013 FR-S Build |
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post: | hmong337 (10-27-2014), strat61caster (10-27-2014) |
10-27-2014, 09:15 AM | #30 |
Drives: '13 BRZ Ltd
The clutch is weird. I'm not so sure if it's a travel issue more than it is a feel issue - it has kind of an ambiguous engagement. I put in a thicker clutch stopper that doesn't let the pedal travel much once it completely disengages. This makes it quite a bit better. Still not a lot of feel but at least I know it starts engaging almost immediately once I lift off the pedal.
10-27-2014, 09:52 AM | #31 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Yes! I just can't seem to get the pedal modulation right for a smooth gas/clutch release. I'm still inconsistent with driving smoothly. This is my first DBW car and I absolutely hate it. All the older style cars like my mr2, I'm super smooth. Drive-by-cable ftw!
10-27-2014, 10:01 AM | #32 | |
I feel like with the 5% dead-zone on the FR-S, I'll "heel" the throttle slightly and get nothing. Then push the throttle slightly more and get too much response for the downshift.
10-27-2014, 10:06 AM | #33 |
Drives: 2013 Firestorm Scion FRS
i dont know if this is what you guys are talking about but have any of you guys tried this?
http://www.ft86club.com/forums/showthread.php?t=8040 it adjusts the clutch pedal so there is less travel and you dont need to push in as far as before. I tried it and it works well. |
10-27-2014, 10:52 AM | #34 | |
I'm with you. I've got 28k on the ticker and can't remember stalling it once. Pretty easy clutch to master in any type of footwear... |
10-27-2014, 03:38 PM | #35 |
Drives: 14 Ultramarine FR-S
Subbing to this thread for sure!
This is my first manual but it feels odd to me, I did the clutch pedal adjustment so that the brake & clutch are pretty much parallel to each other. I grew up on motorcycles have been riding since I was 16 (legally on the road) so I fully understand how to drive a manual. Still though even with less dead travel, the "feel" isn't there for me & as others have mentioned that deadzone on the gas pedal doesn't help either. I'm still kinda frightened by hills lol, I can't imagine parallel parking on a very steeply inclined street in LA. Unsure about removing the clutch spring, I feel as if I may regret it because you can get stuck in traffic a lot down here.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
10-27-2014, 03:51 PM | #36 | |
I've driven cars with longer travels, cars with engagement points just off the floor and cars where the clutch pedal is just a formality that isn't always required. All in all, every car is going to 'feel' different, I just adjusted to it and I really don't have many complaints, maybe if I drive something like you speak of I'll change my tune. My only complaint is that there isn't much feedback once you hit the engagement point, you really have to be looking for it. If I was going to change one thing about this car it'd be drive by wire, but now that I'm thinking about it I have a hunch that you need it for D4-S... Edit: For clarity I haven't changed anything about my car since I got it, I could foresee adjusting the pedal closer to the floor but a prior experience of the hydraulics failing and excess clutch travel giving me just enough clutch action to bump it home in rush hour traffic has me not in a rush to change it. |
10-27-2014, 03:53 PM | #37 |
Drives: 2013 Firestorm FRS
easy to drive, yes.
Easy to feel? F no I hate the clutch in this car. There's about as much feeling from the clutch in this car as poking at the pedals with a broomstick. As far as a clutch delay valve/type thing I dont think there is one. I just think the slave is too big, or the master is too small. @Phantobe After removing the spring, it does get stiffer...but you get used to it very quickly. Never once after removing the spring have I got into my car and thought, "gee, the clutch pedal sure is stiff" |
The Following 2 Users Say Thank You to continuecrushing For This Useful Post: | hmong337 (10-27-2014), Ultramaroon (10-27-2014) |
10-27-2014, 05:23 PM | #38 | |||
義理チョコ
Anyhow, thanks to everyone who responded. I know there have been lots of discussions on the topic but none have really addressed the possibility of changing the "gearing" of the clutch pedal. I'll share if/when I get around to tinkering.
The Following User Says Thank You to Ultramaroon For This Useful Post: | strat61caster (10-27-2014) |
10-27-2014, 05:26 PM | #39 | |
義理チョコ
10-27-2014, 05:29 PM | #40 |
So you're hunting for something you've never experienced?
10-27-2014, 05:36 PM | #41 |
義理チョコ
No. Sorry. Maybe I wasn't being clear. Just about every other car I've driven, bike I've ridden, had a much narrower arc between touch and full engagement, cable or hydraulic, doesn't matter. I've been able to adjust all my vehicles to my liking without ever messing with the pedal-to-throwout ratio. (I'm sure there's a term for that).
I want that feeling back! There's no excuse for this, of all cars, to have a mushy clutch. Edit: Here's my list again: 75 beetle, 76 Chevette, 78 B210 hatchback, 70 240Z, 91 Eclipse Should I also mention the Ferguson TO-30 tractor and the 61 beetle my dad gave me to drive around when I was 9? (just some background)
10-27-2014, 07:48 PM | #42 |
Id have to agree these are one of the more unusual clutches I have every driven...
The Following User Says Thank You to vividracing For This Useful Post: | Ultramaroon (10-27-2014) |
Similar Threads | ||||
Are these fake? | shu5892001 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 04-11-2013 12:57 PM |
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
fake Bugatti anyone? | bofa | Other Vehicles & General Automotive Discussions | 16 | 07-18-2011 02:20 PM |
