Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Software Tuning
Old 05-19-2016, 02:54 PM   #1
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
ECUTEK help/question
Hello, I run a 2013 brz with a kraftwerks c38 kit. Was doing some logs 2 weeks ago on ecutek and noticed the advance multiplier (one of the first lines up top) was in the negative as in -4 to -1. Now I was under the impression that this multiplier should always be positive and over around the .7 to 1.
My question is if anybody has any idea as to why I would show negative advance multipliers... also the car doesn't pull nearly as hard as it should and is gutless in low-mid range (ecutek virtual mustang dyno gave me around 250whp at peak and about 180 tq all the way to redline (based on a 3rd gear and after that a 4th gear pull).
Side note: we did the datalogging based on my other buddy's rom as there was an issue with my usb (KW usb shit the bed). I don't think that would affect anything though as datalogging only looks at numbers given by ecu and does not care about the rom loaded in proecu (is this correct)?
@Moto-Phil @moto-mike
All in all, no knock and the car runs very well but it seems very conservative and the negative advance multiplier has me and several people scratching their heads tbh. I will reflash my ecu with the tune tonight and datalog with the freshly flashed tune to see if anything different happens. I'll send you guys the logs after for my revision(fyi, I own Dan_Brz;Dan Voutier's Brz).
fumanchu1 is offline   Reply With Quote
Old 05-19-2016, 03:07 PM   #2
Ashikabi
Ashikabi's Avatar
You could tag Moto-Mike in here if you wanted, see which one gets here first
Old 05-19-2016, 03:41 PM   #3
fumanchu1
it's a race now lol
Old 05-19-2016, 03:50 PM   #4
Xero-Limit
Tuner
Xero-Limit's Avatar
Drives: 335SC BRZ (ret), STI, RB25 S13
Anything negative and I'd say you're either using the wrong ROM revision to datalog, or you're looking at the wrong parameter. Either way we have no way to link a user name to a customer name so an email would be the best thing
Xero Limit Inc
Tuning & Performance Parts
Easton, PA 18042
Xero-Limit is offline   Reply With Quote
Old 05-19-2016, 04:03 PM   #5
fumanchu1
ok so the rom revision used to datalog will affect the posted results, that explains it I think (as we didn't have my rom file as the usb with my tunes on them shit the bed). I will redo the logs tonight and flip you an email hopefully also tonight.
Thanks for the quick reply as I now know the logs I have are useless atm.
Old 05-19-2016, 05:40 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yup. Different Cal ID logging parameters have different addresses. Different version of racerom patch can also have the same. Use a mismatching file to log can make incorrect outputs.
.: Stealth 86 :.
Litchfield Springs / Abbey MS Geo
Old 05-20-2016, 09:15 AM   #7
fumanchu1
Reflashed and reclogged yesterday and sent my logs to moto-east for revision
Old 05-30-2016, 04:59 PM   #8
fumanchu1
my email lost in the shuffle, lightning fast reply once they were made aware, good stuff
The Following User Says Thank You to fumanchu1 For This Useful Post:
-Phil (05-31-2016)
used ecutek question redlined600 Software Tuning 6 02-27-2015 04:41 PM
ECUTEK Question Triumphrider Software Tuning 5 01-18-2015 05:51 PM
New Guy - EcuTek Question joshb86 Engine, Exhaust, Transmission 2 06-30-2014 03:02 PM
ECUTek question ATSAaron Engine, Exhaust, Transmission 12 04-03-2014 06:37 PM
I have a question on ecutek dannyboy Software Tuning 2 10-08-2013 11:59 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
