Old 03-18-2014, 11:31 PM   #15
Blackrsx
Drives: Red FRS
Originally Posted by sirisvirus View Post
Anyone able to chime in and tell me if these will work?
Power TOP SMD SMT Blue PLCC-2 3528 1210 Super Bright Light LED
They look like the correct ones.
Blackrsx is offline   Reply With Quote
Old 03-23-2014, 05:55 PM   #16
sshole
Odd. I just cracked open my BRZ cluster and it looks like Subaru skimped out on a few LEDs for the BRZ. For example, you have 4 red needle LEDs for your tachometer and speedometer. Mine only has 2. Your tachometer has 5 white LEDs, mine only had 3 red. Oh well. I changed my LEDs to white, but left the digital speedo and odometer red.
I also removed the TPMS LED because that thing is stupid. Most of the LED functions are silk-screened onto the PCB.
sshole is offline   Reply With Quote
The Following 2 Users Say Thank You to sshole For This Useful Post:
flippy (09-23-2014), mixtape (05-28-2016)
Old 03-23-2014, 06:21 PM   #17
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Originally Posted by Blackrsx View Post
Here are the before and after pictures.
Before:
After:
Is it me or does it look brighter before ?
Nice diy btw
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-23-2014, 11:39 PM   #18
Blackrsx
Drives: Red FRS
Looks good! Also looks like if we swapped clusters it would've done the same thing.
The Following 2 Users Say Thank You to Blackrsx For This Useful Post:
mixtape (05-28-2016), Ornelas66 (10-04-2014)
Old 03-23-2014, 11:40 PM   #19
Blackrsx
Drives: Red FRS
Nice diy btw
Brightness is about the same.
Actually I think the white was brighter at night.
Old 03-24-2014, 07:31 AM   #20
sshole
@Blackrsx were you able to get your analog speedometer to reset to 0? Mine, although I marked where it originally was and placed it back in that same spot, seems to want to read 2mph high after plugging it back in. I've reset the needle a handful of times, but every single time it will push the needle up to +2mph instead of 0. I've even set it back to where it would probably read -5mph and the gauge will set the needle back up at +2mph.
I'm going to take it apart tonight to see what's happening. Small issue, but it doesn't matter too much since I use the digital speedo display 100% of the time.
Old 03-24-2014, 01:47 PM   #21
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
How can you tell +2mph on the needle?
^GT5 Replay Photo Mode^
Old 03-24-2014, 01:50 PM   #22
sshole
If I'm at a standstill, my digital speedometer reads "0" and the analog needle is between 0 and the first hash mark, which would indicate 5 mph. It's closer to the "0" hash mark than it is to the "5 mph" hash mark, hence +2 mph.
Turns out you can actually see the needle hovering between 0 and the 5 mph hash mark in my 2nd picture.
Old 03-24-2014, 01:57 PM   #23
SirBrass
SirBrass's Avatar
I think that's just the default position for the speedo needle. Looking at the other pictures in the thread, that's where the needle rests for all of them.
Honestly I don't really notice on my car. I don't even look at the needle there at all, really, b/c in my past Subarus, the speedo was on the right (iirc), and fuel guage was on the left. When driving, I'd be paying attention mainly to the center (tach of course) and right sides of the cluster, so that habit has stayed with the BRZ. I'm way more apt to notice if my fuel guage needle has moved than if my analog speedo even works, lol.
The Following User Says Thank You to SirBrass For This Useful Post:
sshole (03-24-2014)
Old 03-24-2014, 02:30 PM   #24
sshole
I came from a STI, so I know what you're on about. It's just annoying knowing the needle is higher than it used to be. For clarification, the needle did show the same speed as the digital read out before I went and removed the needles.
Old 03-24-2014, 02:53 PM   #25
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
That wouldn't have been as much fun though, right?
Great work both of you!
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
The Following User Says Thank You to codesplice For This Useful Post:
BlackJesus (07-06-2015)
Old 03-24-2014, 03:04 PM   #26
SirBrass
SirBrass's Avatar
I suppose. There's just other stuff that's at that level that's even more annoying, I think: such as fixing back deck rattle, that it wouldn't personally bug me really.
Old 03-25-2014, 09:39 AM   #27
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Great write ups both of you. Ironic how the FR-S guy wanted red and the BRZ guy wanted white...
So how hard is it to actually take the cluster out of the car? I would like to do this just to take out the TPMS LED. I'm keeping the red LEDs for the back lights though. While I think the white looks very clean and it's what I had on my GLI, the red is much better for my old eyes at night...
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
The Following User Says Thank You to BRZNutt For This Useful Post:
sshole (03-25-2014)
Old 03-25-2014, 09:52 AM   #28
sshole
It's not difficult to take the cluster out of the car. Here's what I did:
Tools needed: plastic panel pry tool (or wrap a flat head screw driver with electrical tape), phillips screw driver.
1. Remove plastic surround from radio. In the BRZ it's the silver piece above the center console that surrounds the nav unit. In the FR-S, it's the textured black piece above the center console that surrounds the nav unit. You do not have to remove the extra long piece that is in front of the passenger seat. Use pry tool or flat head screw driver to pop this off from the tops of the knee pad panels of the center console.
2. Remove single phillips screw holding in gauge cluster hood. Look through your steering wheel and you should see the phillips screw head peeking through the top of the gauge cluster surround (the flat black piece with the 3 buttons for mph/kmh, odo, and disp).
3. Remove gauge cluster hood by pulling towards the steering wheel.
4. Pull back the gauge cluster surround.
5. Remove 2 phillips screws at top of gauge cluster.
6. Pull gauge cluster back towards steering wheel and disconnect the wiring harness at the back of the cluster.
The Following User Says Thank You to sshole For This Useful Post:
BRZNutt (03-25-2014)
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
