10-03-2014, 04:07 PM | #2535 | |
Drives: FR-S Firestorm 6MT
I love Vossens, and I actually like your setup on 19's. |
The Following User Says Thank You to Slick For This Useful Post: | FLIPs_FR-S (10-03-2014) |
10-03-2014, 11:46 PM | #2536 | |
10-04-2014, 08:20 AM | #2537 |
You might get lucky and not need any, really depends on your current camber, but if so it will be very close.
Btw, you should clear on the rears since there is more room on the inboard side. |
The Following User Says Thank You to Slick For This Useful Post: | corry29 (10-04-2014) |
10-07-2014, 02:17 PM | #2538 |
Drives: 2013 Toyota 86 MT
Hi
Just got the car and it is completely stock except supercharger kit (will be installed this weekend). Dont have much knowledge about stock fitment even though i tried to read as much as possible from this forum. I am planning to get some 18" concave wheels, squared if possible. Wedssport sa-55m or work kiwami looks nice. I have a very limited budget, so dont want to change suspensions or coilovers or brakes, anyway i'm happy with the ride right now, a little stiffer after 18"s would be fine, just worry about traction after SC. Can you give me some suggestions about wheel width, offset and tire size that will fit stock setup, or at least very low cost setup? |
10-07-2014, 05:53 PM | #2539 | |
+35 to +38 offset Fit some 245/35R18 square |
10-08-2014, 09:55 PM | #2540 |
Drives: Black 2013 BRZ Limited M/T
So im looking into getting the enkei T6S, 18x8.5 +45 and was wondering what a good tire size would be. Im also planning on buying coilovers along with the wheels and lowering my car about an 1".
10-08-2014, 10:09 PM | #2541 |
You should have no clearance issues with that setup, would recommend you look at 245/35R18, ideal size for that wheel.
10-10-2014, 11:47 AM | #2542 |
Drives: 2013 Asphalt FRS 6AT
Ok fellas, I want to run:
Rays 57getter 18x8.5 225/35 front 18x9.5 255/35 rear Can I run it without coils? I wanted to do sportlines or pro kit. Also any suggestions/comments on those wheels and tire sizes? Thanks. |
10-10-2014, 11:58 AM | #2543 | |
Depends on offset of your wheels. For fronts run 225/40R18, 235/40R18, 245/35R18 Rears would be 245/35R18 or 255/35R18. Depends on wheel offsets what tires you can run to some extent. |
10-10-2014, 12:22 PM | #2544 | |
18x8.5 +45 front 18x9.5 +40 rear Thanks on the tires man. |
10-13-2014, 04:06 PM | #2545 |
Drives: FRS
will this fit
18x9.5 +30 on 245/40/18 all 4s
will this fit without rubbing, right now i'm on KW V3 Last edited by CarNoob; 10-13-2014 at 04:18 PM. |
10-16-2014, 12:11 AM | #2546 |
Drives: Toyota GT86
Hey guys,
I am thinking about getting some Work XD9's for my 86! It has stock suspension and i was wondering if anyone knew if the below sizes will fit. I am thinking about having the backs wheels abit wider. Thoughts/opinions. Any help would be great thanks! Default PCDs and offsets available: 18 X 9.0 [45mm dish] - $440 per wheel [ 5-100, 5-114.3 / +30, +38] 18 X 10.0 [73mm dish] - $455 per wheel [5-100, 5-114.3 / +18, +38] |
10-16-2014, 12:37 PM | #2547 | |
Here's a perfect example of that. http://www.ft86club.com/forums/showp...&postcount=156 The tire size you run will depend how much camber you are at. With enough camber though, you could run the 245/35R18, 40 series is too tall. But that may be "too much" camber than ideal, just in order to fit these wheels. Most folks running this same setup are running 225/40R18 up front, no issues in back though. If you have a choice of offsets, try this wheel size in something closer to +38 to +42. |
10-16-2014, 12:43 PM | #2548 | |
For rears with the +38, will poke out quite a bit also. 10" size is pretty wide for the back, you will need to run lots of camber to make it work (Stance Nation) and small tires. See here: http://www.ft86club.com/forums/showthread.php?t=60585 If you go with 18x9 +38 all around, it should give you much better options and fitment. Will also allow you to run a 245/35R18 square, maybe bigger if you are lowered a tad. |
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
