Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > Hawaii
Hawaii Aloha!
Old 11-07-2018, 01:22 PM   #29
unicron
unicron's Avatar
Drives: frs 2015
I have the same issue starting last year at about 70000 km. It feels crunchy as if clutch (linkage, pushrod, return springs etc ) is binding. I tried applying grease to the slave cylinder pushrod where it contacts the release fork, tried flushing the hydraulic fluid. These seemed to improve it until it came back. I replaced the hydraulic fluid again, and could objectively say it had no effect. I then tried lubing all the moving linkage components inside the car ( very complicated linkage setup) where the sound seemed to come from in my case. The problem, if your getting crunchy clutch is probably the pushrod going into the clutch master cylinder is dry. You will need to find a compatible lube that won’t break down the seals and cause further problems
unicron is offline   Reply With Quote
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) -- General Topics 190 01-12-2017 10:24 PM
Squeaks when shifting gears/happens every 15 or so seconds while holding speed Simon99 Issues | Warranty | Recalls / TSB 10 10-11-2014 03:54 PM
door handle/pull squeaks NRG x FRS Issues | Warranty | Recalls / TSB 1 11-27-2013 09:38 PM
I knew about cabin squeaks before I bought the car but... NOMNOM Issues | Warranty | Recalls / TSB 10 05-23-2013 05:00 PM
