Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-23-2018, 11:52 AM | #1 |
Trunk button or fob trunk button aren't working.
Hello, as you may know, I'm a new member in this form here.
As my title says, can anyone help me out? Thanks. Sent from my CLT-L04 using Tapatalk |
10-23-2018, 11:54 AM | #2 | |
Country Boy 4 Life
Welcome to the forum. If your trunk won't open, try the key in the trunk key-hole. The valet button, on the left side of the trunk, probably got pushed on accident. Good luck.
I LIKE TIRES! |
The Following User Says Thank You to Leonardo For This Useful Post: | Spuds (10-24-2018) |
10-23-2018, 12:02 PM | #3 |
thanks for replying back to my post. My concern is to fix the issue and not use the key on the key hole in the back of my trunk. Would you know anyone that would have the parts to replace it and how much will it cost?
10-23-2018, 12:05 PM | #4 | |
Country Boy 4 Life
Did you use the key? After you do, look at the left side of your trunk, your valet button has accidentally been pressed! Push it and it will fix the problem.
I LIKE TIRES! |
The Following 3 Users Say Thank You to Leonardo For This Useful Post: |
10-23-2018, 12:39 PM | #5 |
Panda Trueno
Drives: No twin now.
Like said, check the valet button before thinking you need replacement parts.
Very common issue, searching helps using google. |
The Following User Says Thank You to Summerwolf For This Useful Post: | Leonardo (10-23-2018) |
10-23-2018, 08:23 PM | #6 | ||
Professional Mechanic
Drives: 2017 86 6MT Oceanic
But replace your button if that will make you feel better. |
10-23-2018, 11:03 PM | #7 | |
Now, I suggest you make a post and thank ol @Leonardo for his help. After you post at least 10 times, a "thanks" button will appear at the bottom of peoples posts, where you can thank them. humfrz |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Leonardo (10-23-2018), noodlefish (10-24-2018) |
10-24-2018, 12:12 AM | #8 |
Drives: 2018 BRZ
On my car I have to hold the trunk button/FOB button to open it. Just pushing it doesn't do it.
The Following User Says Thank You to edwardl For This Useful Post: | humfrz (10-24-2018) |
10-24-2018, 02:03 AM | #9 | |
How many out there remember when you got only two keys to a car - one opened the doors and trunk, the other turned the ignition on? In the dark you could tell because one key head was rounded and the other was angular. Back then we didn't have to: * worry about FOB batteries running low * wonder which FOB button to push to do what * worry about a spare; the second set was simply wired up under the car * be concerned about someone remotely skimming your FOB signal * didn't have to pay the dealer hundreds of dollars for a spare key * be annoyed by a big bulky thing in your pocket; just two small keys on a key chain * by the time the keys wore out, it didn't matter because the lock was so worn that you could use a bent 8 penny nail to turn it * what did I miss - humfrz - stuck in the 50s |
The Following User Says Thank You to humfrz For This Useful Post: | 86MLR (10-24-2018) |
10-24-2018, 02:22 AM | #10 |
Climb in from the back seat and have a look if all else fails.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
10-24-2018, 07:33 AM | #11 |
Drives: '17 86
[QUOTE=humfrz;3147693]
How many out there remember when you got only two keys to a car - one opened the doors and trunk, the other turned the ignition on? In the dark you could tell because one key head was rounded and the other was angular. Back then we didn't have to: * worry about FOB batteries running low * wonder which FOB button to push to do what * worry about a spare; the second set was simply wired up under the car * be concerned about someone remotely skimming your FOB signal * didn't have to pay the dealer hundreds of dollars for a spare key * be annoyed by a big bulky thing in your pocket; just two small keys on a key chain * by the time the keys wore out, it didn't matter because the lock was so worn that you could use a bent 8 penny nail to turn it * what did I miss - humfrz - stuck in the 50s[/QUOTE Oh yeah. Remember those days well! |
The Following User Says Thank You to nitro_alltrac For This Useful Post: | humfrz (10-24-2018) |
Similar Threads | ||||
OEM illuminated trunk release button | Guillaume | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 01-10-2018 05:02 PM |
BRZ Key Fob trunk button | Jarrid'sBRZ | BRZ First-Gen (2012+) -- General Topics | 26 | 06-03-2016 01:50 PM |
DIY: Trunk lid button for use with Easygo kit | Chaetagnath | DIY (Do-It-Yourself) Guides | 1 | 08-03-2015 03:51 PM |
Trunk opener button | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 05-13-2014 01:24 AM |
Trunk button not working | Jahdai42 | Issues | Warranty | Recalls / TSB | 4 | 02-19-2013 08:03 AM |
