08-24-2013, 12:10 PM | #57 |
Drives: GT86
08-24-2013, 12:33 PM | #58 |
NASA SpecE30 Racer
Too many tees, too much confusion. I am guessing your CEL has something to do with the fuel vapor vent vacuum hoses. I believe the Full Blown instructions have you tap into the brake booster line with a tee and run that hose over to the BOV where you put another tee and run one line to the BOV and one line to the wastegate. If you want to run more items that need a vacuum/boost source, then you are going to need yet another tee. That is why I like the vacuum manifold solution.
As for your Cusco can, the correct way to run it is to put a check valve in the vacuum line that comes of the back of the manifold and normally runs to the PCV valve. Then after the check valve run the hose to your Cusco can and then down to the PCV valve on the block.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
08-24-2013, 04:49 PM | #59 |
Drives: 2013 Asphalt FR-S
http://www.ft86club.com/forums/showt...service+manual
http://www.ft86club.com/forums/showt...service+manual codes and troubleshooting procedures are in the service manuals.
~Namaste~ |
Similar Threads | ||||
The Jet. Boost build. | jet86 | Member's Car Journals | 310 | 10-06-2015 10:41 AM |
Which boost gauge? | Bigmaxy | Forced Induction | 3 | 07-07-2013 07:11 PM |
E85+boost | subatoy | Forced Induction | 5 | 11-06-2012 11:55 AM |
any way to reduce or eliminate "idle creep"? | Nepenthe | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 07-03-2012 02:00 PM |
AE86 w/F22 + Boost | Dragonitti | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 01-09-2011 01:06 AM |
