05-19-2016, 10:04 PM | #3109 |
Drives: 2014 White Subaru BRZ Limited
Hey guys so currently I have eibach lowering springs on my car (only about an inch lower than stock. I have the stock tires on 17x7.5 rims and 25mm spacers in the back and 30mm spacers in the back.
I'm Kind of sick of having spacers so I was thinking of buying 18x8.5 +35 rims for the front and 18x9.5 +38 rims in the back. Could anyone please tell me what size tires what fit this setup and be able to clear everything including the stock struts. (Also if I will still need spacers) Thanks!
Daily 2014 Satin White Pearl BRZ Limited
Instagram: @subyota |
05-19-2016, 10:28 PM | #3110 |
Drives: 2013 frs; 1988 porsche 944s - > 948
help on tires setup
been pm'ing and posting questions on a setup i want and the wheel directory and the fitment calculator have me perplexed. i would like to have decent rubber to bulge over the tire and protect the rim. looking at konig oversteer 18 x 9at 42 offset and wanting 255/35/18'sto get the meaty look. leaving at stock height as its a daily driver and have winter tires for that season. don't want to buy coilovers but will get spacers to miss the factory coil perch. i'd like to have the sidewall poke with the rim about flush. fitment calculator showed i had this cased with a 12mm spacer on the front and 17 mm on back but a pic of a stretched 245/35/18 with no spacer on bremmer kraft had only 2mm clearance to stock perch and obnoxious poke.
am i asking for the impossible here? consensus? |
05-20-2016, 12:17 AM | #3111 |
Drives: 2016 Scion FR-S
SSR Professor SP1 Wheel - 18x10
need some advice with a wheel and tire combo, SSR Professor SP1 Wheel - 18x10 wrapped with 240/35/18, will they clear the inside? or will i have issues with rubbing? also a 1.5inch drop. thx, new to the forum.
05-20-2016, 04:22 AM | #3112 | ||
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Front 245/35/18 // Rear 265/35/18 this will look about flush with the wheel Front 225/40/18 // Rear 245/35/18 This will have a light stretch. Both will clear without spacers, the front will poke 3-5mm (see the pictures in my journal -> Link in signature) rear is about flush Quote:
For reference -> Check out the following pictures, and add another 5mm to the poke, this is about what your setup will look like http://www.ft86club.com/forums/showp...1&postcount=75 http://www.ft86club.com/forums/showp...4&postcount=98 Need to know the offset to answer it corretly. However, 10" wide wheel will doubtfully fit in front (or poke alot). Also, there is no 240/35/18, so it would rather be 245/35/18. Also, 245 wide tire on a 10" wheel (so 254 wide wheel) will be stretch, and not advisable handling wise. If you're into hellaflush, I'm not here to judge, go for it then.
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
05-20-2016, 10:04 AM | #3113 |
sorry offset +3, I'm going with the rocket bunny kit
https://www.google.com/url?sa=i&rct=...63805650316785 |
05-20-2016, 10:21 AM | #3114 |
Drives: Toyota GT86
Hi guys, i've decided on my build and want to know if this will fit without rubbing using the following kit. http://www.ft86speedfactory.com/ft-8...l#.Vz8cBpMrLMU
Rays 57C6 18x9.5 ET40 Next i'll have to decide on tyre size and whether i go for nankang ns-2r or michelin pilot ss for dd and occasional track use Thanks. Last edited by Tim86UK; 05-20-2016 at 10:32 AM. |
05-20-2016, 12:56 PM | #3115 | |
questions on your response
could you elaborate on why using spacers is not advisable? i get what your saying on the ultra poke and the silly offroad look and agree. but to accomplish a non-issue fitment with 9" all around for ease of tire rotation i'm gonna need some spacer to clear factory perch even with the smaller 245's that i didn't want to stretch over the 9" rim. (gotta compromise somewhere, actually wanted 255's but that seems to be asking the impossible) so although 12mm spacer is ridiculous, perhaps the 5mm or if i can somehow find someone that sells one a 7mm would get enough clearance for the wheel and still let me stay with the 9" all around for great concavey look, and the ability to rotate tires. i would then also just spacer the rear to match the profile of the front. thoughts? or is this still not advisable? in advance, |
05-20-2016, 01:24 PM | #3116 | |
Spacers however always put additional stress on your ... dont know the english word ... point where the stuff is mounted to your car, so thats why I do not recommend it. However, its nothing "totally wrong" with it. (To be fair, lowering the car with springs does also put more stress on the rest of your suspension, so its all just a matter of accepting the facts) 7mm spacers will work, 5mm probably aswell, but depends a bit on the tirebrand and wheels you're using. its very tight in the front. btw, if you put on spacers, I suggest to do the same amount all around.
05-20-2016, 01:28 PM | #3117 | ||
Any why not getting proper coils, the price is not that much off fromt he kti you've linked Tire size I would suggest at least 245/35/18 for 9.5" wide wheels. Maybe 265/35/18 for rear. Also, DONT save money on the tires. They are in the end the most important part of your suspension. Nankang are not know to be high end tires.
05-20-2016, 01:34 PM | #3118 |
my konig dilemma
i'm looking at 245/35/18 hankook ventus v12 evo2's on konig oversteers 18" X 9" which have an offset of 42.
i'd be looking to minimize the spacer to just give me the clearance inside the wheel from the stock perch. there's a thread on the konig oversteer fitment to which a senior member states that going to a 9" in the front will definitely need at least a 3mm slip spacer for clearing on the 245's so i'm guessing the 5mm would do; its just whether it will look good at that. my ideal look would be to have the bulge of the sidewall plucking out of the flush plane of the fender; but since i have my heart set on these high offset wheels; the 245's are most likely going to stretch onto that wide 9" rim so i have to live without the ideal look to get a set i can tire rotate and keep the concaveyness of the 9's. to match the flushness of the front i am going to have to spacer the back unequally. so if i end up doing 5's in the front i'll have to do 10's in the back to match flushness won't i? |
05-21-2016, 11:32 PM | #3119 |
ok i understand, well can you at least tell me if i will have problems on the inside? towards the suspension?
05-22-2016, 04:32 AM | #3120 |
Drives: 2013 Scion FRS
im looking into buying some used rays gramlights 57dr 18x9.5 +38 with 245/40/18 tires. This would be a square setup on stock suspension. From what ive read so far the rears should fit fine with some wheel poke. However, it gets a little iffy regarding the front. Will the front wheels clear the stock suspension with that tire size and offset?
05-23-2016, 11:27 AM | #3121 |
IG: @HypeBRZ
Drives: Series.Hyperblue BRZ
Did some research but I am not the brightest bulb about wheels, wanna double check with you guys if this will fit and be flush with fenders
Drop 20mm on RCE Yellows Front -18x8+40mm wrapped in 235/40/R18 with 5mm spacer Rear -18x8+40mm wrapped in 245/40/R18 with 15mm spacer According to fitment chart that's somewhere on this forum, this would be 1mm off front and rear which isn't a big deal... or am I completely wrong?
05-23-2016, 01:31 PM | #3122 | ||||
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
