Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-14-2022, 10:26 AM | #1 |
Click Here
2013 FRS Intermittent no-crank
As the title states, having issues with my FRS regarding an intermittent no crank. Starter will only turn about 10% of the time when I turn the key. When it does turn, it’s starts up and is completely fine. There’s no grinding or spinning noise when turning the key so I think it’s a connector issue. Just wondering what else to rule out given the circumstances. I believe this is still the original starter so it’s possible that it just needs replacing anyway.
10-14-2022, 12:24 PM | #2 |
Drives: 2013 frs base
Do the dash lights come on when you turn the key on? Do they dim when you try to start the engine? Are you pushing the clutch pedal aaaaalllllll the way to the floor every time?
10-14-2022, 12:58 PM | #3 | |
Click Here
Funny enough, it hasn’t replicated since, so you might be right. I checked the spot at which the starter engages and it’s only at about 2/3 throw - I hope that’s all it is but I’m finding that hard to believe. Last edited by Chezboat24; 10-14-2022 at 05:46 PM. |
The Following 2 Users Say Thank You to Chezboat24 For This Useful Post: | blsfrs (10-14-2022), soundman98 (10-14-2022) |
Similar Threads | ||||
Intermittent no-crank/no-start 2013 BRZ Limited | tobin | Issues | Warranty | Recalls / TSB | 5 | 07-27-2021 10:28 AM |
BNIB Fluidampr Crank Pulley + New Crank Bolt + Crank Pulley O-Ring - SOLD | MJones_RB | Engine, Exhaust, Bolt-Ons | 3 | 03-31-2021 03:07 AM |
2013 scion FRS intermittent p1235 | 140db86 | Issues | Warranty | Recalls / TSB | 1 | 12-08-2020 05:13 PM |
Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 05:57 AM |
BUDDY CLUB P1 CRANK PULLEY KIT: SCION FR-S & SUBARU BRZ 2013-UP (W/AC) | syndicatemotorsports | Engine, Exhaust, Bolt-Ons | 6 | 07-03-2014 03:26 PM |
