Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
02-02-2012, 12:56 AM | #29 |
Mr. Sarcasm
So all in all squared is the way to go to improve handling overall, and staggered for high horespower improved handling only?
02-02-2012, 01:59 AM | #30 |
Drives: Widebody '94 Miata R-Package
Looks like they might come staggered stock. The JDM release party has info on the mm of the tires and they differ front to back slightly.
I <3 my Miata. But I <3 my new BRZ even more! |
02-02-2012, 02:47 AM | #31 |
Drives: Attitude
02-02-2012, 05:59 AM | #32 | ||
Drives: '23 BRZ
I've tracked on McPherson struts, Chapman struts, semi-trailing arms, double-wishbones all around, multilink, etc., etc. in cars weighing anywhere from 2000 lb to 3600 lb. I don't see anything about this car's specs that are particularly novel. For sure it's been a WHILE since there's been a 2700 lb. strut/multilink rwd/irs car on the market, but there is nothing new under the sun... |
02-02-2012, 10:14 AM | #33 | |
Also, I don't remember the last Subaru that didn't have eccentric bolts up front for camber adjustment. My guess is that some of these early preproduction models didn't have them but the actual production cars will. But....pure speculation on my part. Either way you wouldn't be able to get big numbers from the bolts but it would be nice to fine tune with them. I'm sure OEM bolts for other Subarus will work and they're cheap. We will have some pretty unique camber plates for this car. - Andrew Last edited by Racecomp Engineering; 02-02-2012 at 11:25 AM. |
02-02-2012, 10:34 AM | #34 | |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
Added Greddy tire specs... Front- 19x8.5-inch (+45mm) w/ Hankook Ventus V12 EVO 225/35ZR19 Rear - 19x9.5-inch (+35mm) w/ Hankook Ventus V12 EVO 245/35ZR19 (stole from wings)
I wish I was cool enough to have an FR-S
02-02-2012, 10:42 AM | #35 |
Site Moderator
Drives: Stuff
I've driven plenty of cars with staggered setups, and square. Fast S2000 guys go from staggered to non staggered, gee.. I wonder why.
Add in the inability to rotate tires, etc.. I'd rather tune the handling elsewhere than running staggered setups, which are simply not ideal IMO for anything that's not MR or RR. And with these cars if you do run staggered make sure your OD matches (or is EXTREMELY close ie 225/45/17 and 255/40/17) so when you get a flat in the rear you can still move the front to the rear and not cook the diff.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
02-02-2012, 10:51 AM | #36 |
Rocket Surgeon
Drives: PSM GGA OMG
02-02-2012, 11:12 AM | #37 | |
Hot Dog
Drives: quicker than arghx7
It seems you're disregarding the feedback of the only people that have driven the car [the media reviews]. Are you nut-swinging Greddy, defending your emotional or aesthetic preference for staggered setups, or do you actually have information regarding the 86 chassis that the rest of use aren't privy to?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
02-02-2012, 01:11 PM | #38 | |
Kuruma Otaku
Heh...
Because titanium. |
02-02-2012, 01:48 PM | #39 |
Drives: Waiting for the ND Miata
You'll get more oversteer with square and understeer with staggered.
02-02-2012, 02:01 PM | #40 |
Drives: 335i Coupe
I'll wait and allow others to be the guinea pig.
I will probably go square to keep the balance and allow for rotation. May increase width but likely just good summer tires will do the trick. To go flush, that'll just come down to the right offset/spacer use. Oh, and I laugh at needing to offset a 600hp car with a staggered big sticky setup. Be real. Many are attracted to this car not only because of its weight, balance, etc but also because it's easy on the wallet. If you're really going after huge power like that, start with a Corvette. 99.9% of forum members are not going to drop $20k on power upgrades. |
02-02-2012, 02:17 PM | #41 |
2 wheel member
Drives: JZA80, 997.1, Taco
Square on the track and weekend events, staggered for around town.
02-02-2012, 03:58 PM | #42 | ||
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
I hope that clears things up.
