03-22-2018, 08:43 PM | #3151 | |
Drives: 2017 BRZ
I also don't know if it really makes a difference, but I can see this being a turn-off for people that go to ST* because they hate their stock seat in their car. At least the OE seats are reasonably good in the twins, all things considered, as far as support and holding you in. If you're the right size. Maybe for everyone... STX at least seems relatively dominated by modern cars, but I can see this pushing a bigger wedge into classes like STS where it's even harder for current safety equipment equipped cars to compete. Some factory seats get pretty heavy. As someone that hasn't changed seats because local drivers SUCK and I kinda want the extra protection... I don't have a strong objection. It's an interesting development.
03-23-2018, 08:09 AM | #3152 |
Drives: 2015 CWP BRZ
Looks like the new Dunlop Z3 is available on Tire Rack. Anyone going to try them out? I can’t afford to be the Guinea pig lol.
03-23-2018, 10:57 AM | #3153 |
Drives: Some kind of Subaru
03-23-2018, 09:19 PM | #3154 |
Drives: 2022 BRZ
I just got done putting a race seat in mine the other night.......
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
03-25-2018, 11:18 AM | #3155 |
Drives: 2013 FRS
03-25-2018, 12:24 PM | #3156 |
Drives: 2022 BRZ
Corbeau , with a Corbeau seat mount/sliders.
Easy install. Simmons
2022 BRZ 71 STR
03-26-2018, 02:40 PM | #3157 | |
Drives: BlueBurz
Time to write letters man. The fuel rule change just got rammed through, steering wheel take back, now seats...case of boiling the frog slowly. If you like ST as it stands, you(all) need to write letters to the SEB (see link below) to tell them to stop ****ing with the fastest growing classes in Solo. Fuel rule was over 15 years old. Seat rule has been around for a long time-these changes cost us $ and have nothing to do with class growth-unless you want to kill it. If you wanted to piss off the rank and file and slowly kill a growing class, this is what it would look like. SEB does listen if enough people speak up. Write your letters: https://crbscca.com/?page=submitLetter |
The Following 2 Users Say Thank You to kinghurl For This Useful Post: | justint5387 (03-28-2018), whataboutbob (03-29-2018) |
03-26-2018, 05:20 PM | #3158 | |
Drives: 2022 BRZ
Simmons
2022 BRZ 71 STR
The Following 2 Users Say Thank You to Simmons For This Useful Post: | justint5387 (03-28-2018), tigermack (03-27-2018) |
03-26-2018, 07:46 PM | #3159 |
Drives: BlueBurz
The Following 3 Users Say Thank You to kinghurl For This Useful Post: |
03-26-2018, 09:48 PM | #3160 |
Drives: 2013 Satin White Pearl BRZ
I just finally got these damn seat. Wtf
Sent from my Pixel using Tapatalk |
The Following 2 Users Say Thank You to jbailey8748 For This Useful Post: | justint5387 (03-28-2018), tigermack (03-27-2018) |
03-27-2018, 01:52 PM | #3161 |
Drives: 2014 scion frs
I installed my Mann rear bar All set for my first event this sunday. Im really proud of my alignment also, Front camber L & R -3.7 Front Caster L=6.7 R=7.0 Front toe Total=-0.16 deg L & R -0.08 Rear Camber L & R = -2.5 Rear Toe Total = 0.18 deg L & R 0.09 Ride height is a little taller than Id like but that because the MCS were originally designed for street class and have the 30mm taller shafts as compared to the standard MCS dampeners.
2014 Scion FR-S # 73 STX - Philly Region, Norther New Jersey Region Grid Chief, Brandywine Motorsport Club DOY 2017 Chief Course Designer
03-28-2018, 01:36 AM | #3162 |
Drives: 4 wheels
Are those endlinks installed correctly?
The Following User Says Thank You to justint5387 For This Useful Post: | Mr.Scion (03-28-2018) |
03-28-2018, 11:07 AM | #3163 |
Yes. I’ve been hearing a lot about this recently. The car was on jack stands. I triple checked to make sure they’re on the correct way. Here is a picture with the car on the ground
03-29-2018, 09:38 PM | #3164 | |
Drives: BlueBurz
******************Begin Letter*************** Stated Core Values of SCCA SOLO Triangle 1. Increased Participation and involvement a. This value is listed at the peak of the triangle as the premier core value 2. Variety of competition experiences 3. Evolving rules in a planned manner The ST growth rate is over 62% taking just the last 10 years into consideration. This alone suggests that the SCCA is meeting the Top core value of the SCCA Solo triangle of Increased participation and involvement. I contend that the propsed changes to ST 14.2.B are at odds with that core value. The Minimum seat weight and airbag rule proposal is being put forward to “better align the allowances with the weights of todays common seats and mounting hardware.” Firstly, there is no such thing as a “common” seat. Stock ND Miata seats come in close to the actual minimum weight of todays’ rules and Stock BMW seats are no where near it and in some cases double the minimum weight. It’s a poor argument. Worse yet, it is a reversal of class intent to make a class designed to represent the common things an enthusiast would do. Now suddenly we need to be “better aligned with today’s common seats and mounting hardware”(what exactly is a “common seat”?). Many of the Stock ST seats weigh more than the proposed 35lbs and significantly more than the current 25lb rule making them ideal candiates to change under current allowances. The purpose of the additional 10lbs is unclear and ill thought out as it has nothing to do with safety and seems to impose an undue financial burden on a majority of the ST participants. At the very core of the SCCA Solo Triangle is the evolution of rules. Takebacks, as this would represent, are not an evolution of rules designed to attract members(their reason for showing up has not changed), but represent a REvolution that does nothing to continue to welcome this unique class of P1s. The continued takebacks of long standing well regarded and accepted rules are more likely to have the “take my ball and go home” effect vs driving towards the main core value. Fuel takeback, propsed steering wheel airbag take back are just some of recent annoyances that if not addressed will continue unabated and finally stifle continued growth. It’s time to stop. One of the things that makes SOLO racing so attractive is the purity of the concept-there are no spectators to cheer us on, it’s driver vs driver and keeping it driver centric is the key to our continued success. Drivers want cool racing seats in the aftermarket, this is the target audience of ST. Let’s not loose sight of this. The ST seat allowance has been in effect for over 10 years and the over 62% growth in the class since that time is evidence of the SCCA meeting the top core value of increased participation There are a few well reported cases (some occuring at Solo Nationals 2017) of airbag deployment without impact in racing and some street driven scenarios. The strong adherence to course set up safety rules within Solo has made it remarkably free from incidents where having seats with integral airbags have been relevant. If the argument is made for these being street driven cars, consider that the bulk of cars in ST are street registered and reflect the desire of adult participants to make certain modifications to their street driven cars. They understand the risks of seats with integral air bag removal and have spoken with their participation. This unique class of P1 adults represents the SCCA solo’s fastest growing class and they have come off the streets to this venue of like minded auto enthusiats. Let’s ensure they continue to be welcomed. I oppose this rule change proposal on the above grounds and think this progression (Airbag take back, Fuel take back) represents moves that serve only to alienate the very unique class of P1s. www.sebscca.com ****************End of letter****************** If you think someone else will send the letter so not to bother, hear this: the current Fastrack indicates it's still open to responses on the way the most recent take back is being received: Fuel... The SEB is listening, but this is your club and your response matters. Waiting to speak up at one of the town halls is too late-they simply don't occur frequently enough. This is one time where voting "often" is not frowned upon. |
The Following 4 Users Say Thank You to kinghurl For This Useful Post: |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
