08-30-2014, 09:11 PM | #85 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Thanks for the information man, i do not have an engineering background and just learning this for my personal enjoyment/knowledge, are there any books you could reccomend? Also yes SW is easy to Torrent :P
08-30-2014, 10:16 PM | #86 |
Drives: 93 MR2 Turbo; 2014 BRZ
You're welcome. Books to???? Learn about solidworks? Or mechanical books?
The Following User Says Thank You to eric6 For This Useful Post: | #maverick# (08-30-2014) |
08-30-2014, 10:25 PM | #87 |
08-30-2014, 11:12 PM | #88 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
That's an interesting setup on the mr2. Any specs on the sw20 build? That intercooler setup looks awesome!
08-31-2014, 04:06 AM | #89 | |
Honestly, I've learned more on my own then any books in school. The books in school are very basic... like the basics of the basics. My recommendation... use google when you run into issues and build things that are interesting for you. The good thing with SW is their are tutorials everywhere. Shoot for completely defined (all black) sketches.
Since then I upped the boost to 26 PSI, the intercooler, 2.5" to 4" exhaust, and the intake manifold. When I cracked the block, I think I was around 500rwhp and my injector duty cycle confirms 480+. And here I am, waiting on the very custom engine to be built. |
The Following User Says Thank You to eric6 For This Useful Post: | frsvr4 (09-15-2014) |
08-31-2014, 01:19 PM | #90 |
Emperor JDM
Woah! Definitely not off the shelf. You doing pumpgas or e85? Any heat soaking with that intercooler setup? I'm in the midst of gathering parts for a water2air intercooler setup but would rather an air2air. Problem is space since we know how tight the mr2 is for that. I am nit going to cut my trunk either as I am one of the few that actually does use it.
But seriously, why the custom motor? ATS could easily send you a 2.2L within a few weeks and they're pretty much the most knowledgable 3sgte builders around. But yea, 450 horse in an mr2 must be wild! I'm looking to push only 320whp with a KO Sb50 kit on a stock gen3 for simplicity. Stock ecu too. Any more and I'll be following you down that rabbit hole.
08-31-2014, 03:51 PM | #91 | |
Why custom motor? Because the 3s doesn't really have a solid motor build in my opinion. I've had issues with ATS build quality in the past (not engines but parts) and I think going to a stroker with a 3s is the opposite way you want to go. They have a short rod from the factory, increasing the stroke even more just doesn't make sense to me. Hindsight, being 20/20, I would have done a much closer to stock-like build though, as waiting 1.5 years for an engine SUCKS! Stick with 300 and keep it fun . 450+ is fun and all chasing down Z06's, GT-R's, mustangs, etc... but it comes with one hell of an upkeep and their is always someone quicker. |
08-31-2014, 07:32 PM | #92 |
Back on topic:
Added another resonance chamber targeting 1450 RPM, exhaust note is definitely getting to a point that I really like . Welding has improved as well. And a picture with a nice AZ sunset: Last edited by eric6; 01-13-2015 at 12:45 AM. |
The Following User Says Thank You to eric6 For This Useful Post: | civicdrivr (09-01-2014) |
09-07-2014, 12:31 AM | #93 |
Legitimately one of the hardest things I've done in a long time. 12 hours straight to figure out how to get somewhat accurate suspension geometry to properly load the LCA. One step closer.
Front(ish) View Top(ish) view Last edited by eric6; 01-13-2015 at 12:46 AM. |
09-07-2014, 11:21 PM | #94 |
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Dry sump oil system needed badly!
09-09-2014, 02:28 PM | #95 |
It's a possibility. We need to get a lot of data first and we have quite a few other larger projects in the works, but it has been discussed .
Here are some finished pictures of the 3s dry sump: Last edited by eric6; 01-13-2015 at 12:48 AM. |
09-09-2014, 02:52 PM | #96 |
Daedalus Moto
I want to be able weld aluminum that's awesome! I guess really just be able to weld in general lol
09-13-2014, 10:32 PM | #97 |
I taught myself... it's all about getting behind the welding mask and putting that pedal down and learning.
09-15-2014, 12:07 PM | #98 | |
Daedalus Moto
Soon enough man I will buy one! Not sure what though ha. I'm decent with arc and gas but I've only put my hands on a tig and mig once Car is looking good though love the front splitter
Similar Threads | ||||
Ericmpena's SWP BRZ | ericmpena | Member's Car Journals | 32 | 08-28-2016 01:01 PM |
Engineers Certificate needed for turbo kit? | happytimetom | Forced Induction | 18 | 02-23-2014 05:47 PM |
Eric @ Beat-Sonic | tysoNgwaNg | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 12-15-2013 08:33 PM |
Software and electrical engineers look here | jonbonazza | Engine, Exhaust, Transmission | 6 | 09-15-2013 11:06 PM |
Scion test engineers can't drive (Hyundais) | holmesbrz | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 02-28-2012 02:11 AM |
