Old 06-14-2022, 01:23 PM   #1
Sliver_bullet
Drives: 2014 Argento Scion Frs
Normal knock correction and final multiplier
Hello everyone,i tried to search around and found nothing that could help me. i have a Turbo’d FRS on E85.
when it comes to Advance Multiplier and Knock Correction, what are the values that you should be worried?
I know 1.0 for AM and 0 degrees knock correction is ideal. But does that mean i should worry if they dont stay there?
I noticed that when i go about half throttle i start to get a couple degrees of Knock Correction in the low/mid RPMs. If i cruise at a somewhat constant speed for a while, AM starts to drop down to the .70’s.Not sure if i should worry, car feels perfectly fine to me. Thanks in advance
Sliver_bullet is offline   Reply With Quote
Old 06-14-2022, 06:06 PM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Im no tuning expert, but it sounds like the tune is expecting full E85 and getting E60-70. Knock is never good. I advise bringing it to a tuner and backing it off a bit.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
The Following User Says Thank You to Westen86 For This Useful Post:
DarkPira7e (06-14-2022)
Old 06-14-2022, 06:30 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Advance multiplier changing is concerning. Datalog and submit it here, you can upload to datazap.me
Old 06-14-2022, 07:17 PM   #4
Sliver_bullet
I have a flex fuel kit so it should be correcting it right? Im currently sitting at 80%. Sorry i should have clarified that.
Should i send a cruising log? Or a stop and go log?
Old 06-15-2022, 03:55 AM   #5
steve99
Drives: FT86
knock at cruise especially in high gears is common issue. A lot of tuners dont check the tunes on highway just on dyno so it gets missed.
can be fixed
knock correction or flkc of -1 or less is fine , especialky if advance multiplier stays at 1. The occasional drop to 0.9 is ok but if its considpstently dropping to 0?7 or below probably worth looking at adjusting tune
Old 06-15-2022, 03:13 PM   #6
FrickingReallySlow
Drives: 2015 FR-S
can be fixed
Is this because of close loop AFR target being closer to stoichmetric? tip in knock from the throttle plate? or closer to lugging engine at <3K rpm in 6th gear
FrickingReallySlow is offline   Reply With Quote
Old 06-15-2022, 05:45 PM   #7
steve99
Drives: FT86
Can be combination of all three
to little fuel
too uch tiing
too little fuel on throttle transients
ues high load in high gears tends to cause knock
Old 06-17-2022, 03:51 PM   #8
Sliver_bullet
Update, it appears that my overpipe hitting the subframe was triggering the knock sensor. Advance multiplier has been at 1.00 for a couple of days vs before i simple drive to work (about 20 minutes) would make it drop.
There is still a few degrees of knock correction on partial throttle acceleration. My question is what should i be monitoring? Knock correction or ignition correction? Also what is FLKC and IAM?
The Following 2 Users Say Thank You to Sliver_bullet For This Useful Post:
DarkPira7e (06-17-2022), steve99 (06-18-2022)
Old 06-18-2022, 07:11 AM   #9
tomm.brz
Drives: brz 2017 hksv2
both of them
flkc = ignition correction ap fine
knock correction = ign correction ak knock
both are relevant
AM = advance multiplier
IAM = initial advance multiplier, meanign the advance multiplier as set for right after startup, in oem tunes is set at 0.7 for example
Knock Correction dholloway543 Software Tuning 3 11-05-2019 03:51 PM
Knocking without knock correction and knock correction without knocking SorryTires Software Tuning 8 06-17-2017 03:57 AM
OFT Beeping, Knock Correction Blinking Nothingman Software Tuning 5 01-25-2017 03:07 AM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Knock Correction Maping Toyota John Software Tuning 12 08-06-2014 06:44 AM
