Old 07-25-2018, 09:36 AM   #29
gtengr
Drives: 2017 BRZ
Originally Posted by Firecruiser View Post
With different scales on a axis a visual comparison is not possible. I'm not sure how to make use of the graphs though so maybe it doesn't matter but for someone just glancing at them to compare they look fairly identical when there are significant differences between them.
The difference in scales isn't relevant imo. Essentially, the way to use those graphs is to estimate your horsepower at X psi, and see how the pressure ratio lines up with the efficiency of the blower. In my examples, I assumed a flywheel horsepower of ~320 hp (I used an Ace header in my analysis), and then making some more estimates I assumed the FA20 is flowing between 28-30 lb/hr of air at 7000 rpm to make ~320 boosted hp on the X-axis. Using boost logs, I then estimated the pressure ratio on the Y-axis, and plotted them to see where they fall on the efficiency curves of each blower. It's not an exact science by any means, but that's the process.
gtengr is offline   Reply With Quote
The Following 3 Users Say Thank You to gtengr For This Useful Post:
CSG Mike (07-25-2018), mrg666 (08-04-2018), wparsons (07-25-2018)
Old 02-16-2019, 12:45 PM   #30
HaXx
Drives: jrsc_brz
C30 with high boost pulley, injectors/feul pump, full exhaust sound like a good setup?
I have the c30 with a catback. Everything else oem.
I'm thinking about adding the hbp/injectors/pump and heads/overpipe/frontpipe. I'm wondering if I can leave it at that or if other supporting mods have to be done
HaXx is offline   Reply With Quote
Old 02-17-2019, 07:26 AM   #31
mrg666
pessimistic skeptic
mrg666's Avatar
Have you seen the post #8 in this thread? I wouldn't use HBP without at least upgrading the connecting rods and bearings.
The Following User Says Thank You to mrg666 For This Useful Post:
HaXx (02-17-2019)
Old 02-17-2019, 08:17 AM   #32
HaXx
Drives: jrsc_brz
That what u did when u went hbp?
Old 02-17-2019, 08:41 AM   #33
mrg666
pessimistic skeptic
mrg666's Avatar
I still have the stock pulley with CARB tune.
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Ti Racing pulleys diss7 Engine, Exhaust, Transmission 0 12-17-2013 03:15 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
