04-01-2014, 02:40 AM | #1 |
Boosted Member
Drives: 2013 SWP BRZ Limited
rear diff riser, welder needed
So I'm planning on purchasing the rear diff risers from PSM, as well as the sub frame risers as well.
Only issue is that one of the parts need to be welded in. what shop do you recommend for a job like this or can any welders do this with the correct instructions? Ive found out that just changing out the rear axles is not good enough to drive this car hard when lowered. the diff needs to be raised.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
04-01-2014, 11:27 PM | #2 |
Drives: fr-s
PRE would be a good choice
04-02-2014, 01:27 AM | #3 |
Drives: 2013 Whiteout FRS
SVPerformance on Sandy does welding. Have a friend who used to work there; they build drift cars.
http://svperformance.net/index.htm |
Similar Threads | ||||
IS300 M85/M98 rear diff - does it fit? | PantsDants | Engine, Exhaust, Transmission | 39 | 03-28-2017 08:28 PM |
FBM 8.8 IRS Rear Diff Conversion | FullBlown | Forced Induction | 133 | 12-26-2015 10:35 AM |
Rear diff LSD question | Dephective | Engine, Exhaust, Transmission | 15 | 09-01-2013 05:30 PM |
Rear diff service | JoeBoxer | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 11-06-2012 10:23 PM |
T1R Rear Diff colars ! | AJ PwR | Engine, Exhaust, Transmission | 0 | 10-09-2012 10:00 PM |
