09-11-2019, 05:11 PM | #3711 |
Drives: 2013 FRS
09-11-2019, 06:27 PM | #3712 |
Drives: 2013 Subaru BRZ Premium MT
CoolHandMoss, your post from yesterday (#3707) really resonated with me.
I do have a different setup than you, but the mid-corner push, and the inability to trail brake, were the symptoms of my issue. I also went through the process of trying different driving styles and lines to make it work. However, I did end up correcting most of the issue in car setup. For reference, here is an abbreviation of the setup I ended with at Nationals. Racecomp Engineering Tarmac 3 Clubsport on 9k springs. Stock front sway bar on shortened Hotchkis endlink. Mann Engineering rear sway bar on medium with RacerX endlinks. I do have an LSD. I have no rake, -3.9 front camber and -2.9 rear camber. My tire temps are about 3 degrees F different from outside to inside (inside is hotter) on concrete with BFGs or Yokohamas, with the fronts being about 5 degrees warmer. I am using stock brakes, but with HP+ pads. I only use the button-press method to turn off traction control and stability control. Prior setups this year included stiff front bar with soft rear bar, stiff rear bar with soft front bar (very, very tail happy with this). I had all kinds of settings for the dampers. I knew to soften the front, and stiffen the rear, but I didn't hit on the right settings for quite a while In my testing, I ran at lots of types of events this year, and had many co-drivers to help with input. It wasn't until the final few events that I got close to a balanced setup, and the final test-n-tunes at Nationals by my co-drivers (STXL and STX) put it together. As you can imagine with 9k springs, I'm running rather soft bars and settings for my dampers. Still, with the final issue of mid-corner push and lack of trail braking, we had to soften front low speed compression, and soften the rear rebound and high speed compression. My final settings were (all from soft): front 7 rebound, 3 high speed compression, and 2 low speed compression; rear 7 rebound, 4 high speed compression, and 5 low speed compression. For context, full hard would be 20, 14, 6. Yes, I run out of travel in the front. I will be replacing my front 9k springs with 7k, because I believe that will help the car get more mechanical grip. In the end, the car handled great for initial turn-in, mid-corner felt good, and we could trail brake again. For context, me and my co-drivers were 87 STX (ProSolo Finale and Nationals), 187 STX (ProSolo Finale and Nationals), and 87 STXL (Nationals). Your setup is different, but hopefully this will help you think through your specific scenario. |
The Following 2 Users Say Thank You to sifl For This Useful Post: | cjd (09-12-2019), strat61caster (09-11-2019) |
09-11-2019, 06:36 PM | #3713 |
Drives: 2013 FRS
Thanks for your response. I have to ask though, if you are already running out of travel in the front, why are you softening the front springs? Softer only helps grip until the travel stops and then you go backwards in my experience.
09-11-2019, 06:55 PM | #3714 |
I still think I'm not getting the level of grip that the car is capable of achieving, especially when I look at my ProSolo data. Front to back weight transfer for launches and pin turns was too abrupt. Without being able to increase front rebound (which I tried, but it caused more pushing on corner entry), I'll always have more front end lift in the front in launches and sharp corner exits than the softly sprung cars. My rear tires couldn't hook up in launches, or I would get too much oversteer in tight corners rolling onto the throttle.
I have a lot of tuning capabilities with my dampers, so I'm taking the chance that I'll be able to get my damper tuning right to work with the softer springs. |
09-11-2019, 07:31 PM | #3715 |
Drives: 2013 FRS
I would be curious to hear how that works out. Another option I have considered is less front spring, more front bar and to raise the front ride height 3-4mm to maintain travel with the increased front end dive. I hate making so many changes at once though.
The Following User Says Thank You to CoolHandMoss For This Useful Post: | strat61caster (09-11-2019) |
09-11-2019, 08:58 PM | #3716 |
You can still step through the changes and see how they feel, I think ride height as an adjustment seems under utilised in autox, understandable as it's not easy to do on a car with fenders. Problem is the number of events to test changes...
Cheers to the setup sharing sifl |
09-11-2019, 10:36 PM | #3717 |
Drives: 15 BRZ
Anyone had a chance to play with the Yokos yet?
Also, I may have a bent tie rod. Are there any aftermarket options that or legal or is OEM good enough?
Delta/CENLA Region SCCA - DS
09-11-2019, 11:13 PM | #3718 | |
Custom User Title
I personally don't like them very much because of the increased heat maintenance required but they are faster so if you're not running them you're at a disadvantage.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
09-12-2019, 07:23 AM | #3719 |
Drives: 2016 Scion FRS
09-12-2019, 10:28 PM | #3720 | |
Drives: 2013 FRS
I have been thinking about it and realized I may have lost some front compression travel when I changed out the camber plates not long ago. It may be a matter as simple as removing the bump stops. So that is the first thing I am going to check on now. |
09-17-2019, 11:21 AM | #3721 |
Drives: 2017 BRZ w/PP
so tire size for a 17+ with a final drive, still run 245 or move up to 255?
09-17-2019, 11:45 AM | #3722 |
Drives: #337 2017 Toyota 86
It will depend on the course, but I'd wager the 255 is going to be more advantageous than not. I've driven some 13-16 cars the same day as my 17 and there is a big advantage to less shifts.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
09-17-2019, 12:20 PM | #3723 | |
Drives: 2013 FRS
So, going forward, my plan of action is to experiment again with front tire pressures, start significantly higher and work down. Then I'll try softening the bar as soft as it will go. I'll play with lower and higher front compression settings. I'll try increasing rear rebound and decreasing front rebound. If I'm still not there I'll put my 450 lb springs in the rear and I'm sure that will give up all kinds of rear grip but likely solve the front grip problem. |
09-17-2019, 12:49 PM | #3724 | |
Where is your front toe? I feel like toe out causes mid-corner push. Also, what happens when you stiffen the front bar or spring? Also, is this solely inspired by Lincoln? Or does the car generally handle that way? |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
