03-10-2019, 09:48 PM | #3543 |
Drives: 2013 Raven FR-S
What's the verdict on trunk junk? Do you guys keep the spare tire and tools in the trunk during events or totally remove them? I usually remove everything but some other 86 guys at events have told me leaving them in actually helps keep the rear in check. Also, do you get alignments with or without the trunk junk?
03-13-2019, 01:43 PM | #3544 |
STX 188
There is something wrong with their setup if they need that weight to keep their rear in check, imho.
The Following 2 Users Say Thank You to tigermack For This Useful Post: | justint5387 (03-20-2019), strat61caster (03-13-2019) |
03-13-2019, 02:10 PM | #3545 | |
btr.life
Drives: 2022 GR86
Do alignment/corner balance with everything out, in race configuration, and driver (or weight) in drivers seat.
The Following 2 Users Say Thank You to justinco For This Useful Post: | smg1138 (03-13-2019), strat61caster (03-13-2019) |
03-13-2019, 07:49 PM | #3546 |
Drives: 2013 Subaru BRZ
Agreed, take everything out, but remember to leave the black Styrofoam pieces clipped in to stay legal (not a fan of this, had to find new clips after I broke or lost all of them).
The Following User Says Thank You to PointDSM For This Useful Post: | smg1138 (03-13-2019) |
03-13-2019, 09:30 PM | #3547 | |
Drives: 2017 BRZ
I suspect only the spare could legally be left in - the rest may not qualify as adequately secured, since it's just pressure-fit into the foam. With the cover it may be enough, but that's just held in by gravity. The foam, of course, must stay no matter what. I find the car performs nominally better below 1/8 tank - something just feels better on fast transitions, and I have a tiny bit more control over yaw with the pedals. Stuff in the trunk? no thanks!
The Following User Says Thank You to cjd For This Useful Post: | smg1138 (03-13-2019) |
03-14-2019, 12:55 AM | #3548 |
Drives: 15 BRZ
Anybody gonna be at the Grenada ProSolo?
Delta/CENLA Region SCCA - DS
03-14-2019, 01:11 PM | #3549 |
Custom User Title
3M tape works well for this.
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
03-14-2019, 02:14 PM | #3550 |
03-16-2019, 01:25 PM | #3551 |
Drives: 2017 86
03-31-2019, 06:28 PM | #3552 |
Drives: 2013 frs
I have a question regarding seats. Do the tillett b5 with the pads count as covered? I know they dont make weight but if you have them can you add weight to offset the 25lbs rule?
https://www.torqued.io/tillett-b5-race-car-seat |
03-31-2019, 10:32 PM | #3553 | |
Drives: 2017 86 6-Speed
The rule in question reads: The driver and front passenger seats may be replaced with the follow- ing restrictions. The seating surface must be fully upholstered. The top of the seat, or an attached headrest, may not be below the center of the driver’s head. The seat, including mounting hardware, must weigh at least 25 pounds and must be attached using the OE body mounting holes/studs. Additional mounting points may be added. Definitely a gray area. We need a definition of "seating surface." Everything you're sitting on is covered. But the entirety of the surfaces you're sitting on is not. If they're legal I might pick these up though, cool seat. Seems like it would save me from having my helmet squished up against the roof like I do now lol.
2017 86 set up for CS STX autocross
04-01-2019, 07:34 AM | #3554 |
Drives: 2013 FRS
I'm on the fence about registering for the Finger Lakes Tour on Wednesday. Anyone else going? It looks like it's usually a pretty good event.
04-01-2019, 10:34 AM | #3555 | |
Scott M
Drives: '13 BRZ (DocWalt's old car)
Scott
13 BRZ (STX prep)
14 Lotus Evora S 06 BMW Z4M Roadster, 01 740i |
The Following User Says Thank You to Molez93 For This Useful Post: | strat61caster (04-01-2019) |
04-01-2019, 07:08 PM | #3556 | |
Drives: 23 BRZ 15 Impreza
Scott, it's Mike! I've made the jump to STX as well. Welcome to the dark side |
The Following User Says Thank You to cueball89 For This Useful Post: | Molez93 (04-01-2019) |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
