Member's Car Journals Car journals by our members. |
10-31-2023, 08:46 AM | #127 |
Drives: Subaru BRZ
Went to Barber last weekend. Changed engine oil and transmission fluid afterwards, 734 miles on the new transmission.
The car is slightly vibrating at idle due to the engine mounts, if this persists, raising the idle to 900 rpm should take care of it. The engine/exhaust sounds amazing at WOT, quite guttural and raw, I can finally hear rpms building up from inside the car. |
The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | RedReplicant (10-31-2023), villainous_frx (10-31-2023) |
12-19-2023, 10:15 PM | #128 |
Drives: Subaru BRZ
Latest oil analysis.
The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
12-20-2023, 12:11 PM | #129 |
Drives: Toyota GT86
you should try using a GL-4 only oil in the trans vs a GL-4/GL-5 hybrid. I switched out my gear 300 for amsoil MTL and felt the shifts were smoother. Mostly a piece of mind thing in the end... Kinda sucked as I had JUST put in the gear300 lol
2014 GT86 Orange 6 Speed https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | Code Monkey (12-20-2023), DocWalt (12-21-2023) |
03-26-2024, 01:06 PM | #130 |
Drives: Subaru BRZ
Well, the clutch started slipping after two hpde weekends so here goes another tranny pull. Out with the old, in with the new...
The Following User Says Thank You to Code Monkey For This Useful Post: | RedReplicant (03-26-2024) |
04-16-2024, 06:10 PM | #131 |
Drives: Subaru BRZ
The BRZ just turned 2 years old, put 3,761 miles in year 2, 11,481 miles total. |
Similar Threads | ||||
2017 Subaru BRZ hpde build | Code Monkey | Member's Car Journals | 207 | 04-18-2022 10:11 AM |
2022 BRZ JDM Spec build at HKS USA for SEMA2021 | 143 | BRZ Second-Gen (2022+) -- General Topics | 5 | 02-14-2022 12:27 PM |
redSerpente’s HPDE/86CUP Street build | redSerpente | Member's Car Journals | 10 | 04-26-2021 06:50 PM |
LS3 HPDE / Time Attack Build | RavioliG | Member's Car Journals | 17 | 02-11-2018 03:56 PM |
86_Freak - Build for DD/C Street/HPDE duties | 86_Freak | Member's Car Journals | 3 | 03-07-2016 09:15 AM |
