Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-20-2022, 12:15 PM | #141 | |
Rust bucket enthusiast
11-21-2022, 06:57 PM | #142 |
Drives: GT86
Hello everyone,
hope you can help me, because I'm a newbe in engine building. I found a lot of infos in this thread, and I recently work on the timing cover to improve oil performance on FA20. I - opened the oil galleries' covers - ported oil galleries - cleaned - used an anaerobic sealent (Loctite 518) before reinstalling the covers and a threadlocker for the bolts - installed an high volume oil pump kit - used an engine lube to prime the new oil pump Now I notice a little lube leak in the rotor of oil pump, after installing the cover... If I spin a little, some lube came out (see attached picture)... Maybe it's normal, I don't know. Do I have to worry? Rotor with cover installed and lube leak (this is the inside view on the timing chain cover): Oil pump primed before installing the cover Last edited by Leviathan83; 11-21-2022 at 07:22 PM. |
11-21-2022, 08:47 PM | #143 |
Drives: Crapcan
The only thing sealing the pump in the cover is a slight amount of friction. It's normal.
11-21-2022, 10:48 PM | #144 |
義理チョコ
Think about it this way. It has to leak a little in order to lubricate itself.
11-22-2022, 11:28 AM | #145 | |
Drives: GT86
I thought about that, but I wasn't sure... Thanks! |
11-22-2022, 12:43 PM | #146 |
義理チョコ
Most welcome! Good luck with your build.
Similar Threads | ||||
FA20 Engine Oiling, Bearings, and Starvation | Element Tuning | Engine, Exhaust, Transmission | 783 | 01-26-2024 02:48 AM |
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response | bren5279 | Forced Induction | 12 | 03-14-2017 07:34 AM |
Buddy Club Race Spec Coilover Problems on Problems on Problems | mpross | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 09-04-2016 11:18 PM |
An alternate solution to Drone problems | 86-tundra | Engine, Exhaust, Transmission | 1 | 09-26-2013 02:50 AM |
Question about oiling filters | showbe | Engine, Exhaust, Transmission | 7 | 10-25-2012 09:50 PM |
